Dmt po
Can you close PO using DMT? We have a bunch from the past we need to close.
I would assume so. PO Header DMT includes the OpenOrder field. include that in a test DMT set to “False”.
I haven’t tested, but generally if you can close a PO manually, you should be able to use DMT to do it.
