DMT Project Criteria - MilestoneID 'Input string not correct format'
I am trying to use DMT to setup Sales orders, Projects, Jobs, Demand, Milestones and finally apply Project Criteria to the Milestones.
I have got my SO’s in, jobs linked, scheduled - all that good stuff - when I go to apply the Criteria I get the error in the title
‘Input string was not in the correct format.’
However this is only occurring on Criteria that are of Type J or ‘Job Operation Complete’.
In the same file I’m loading F types (Fixed Date) and they are going in with no issue. The milestone ID format is the same (8 characters).
this is a snip of the initial csv
I have tried removing the fixed date lines from the csv, and I’ve taken out the spare date column that’s there - but it’s still not working.
I’m on 10.1.600.38 for Epicor - and DMT is always telling me it’s up to date.
Looking for someone with experience in this area - or who might have been through this.
Thanks.
JK
When I took DMT training which was a decade ago the advice was to duplicate errors in the UI to see if you could get a clue what else was needed. Sometimes it is another field is missing for that type or just the order of the fields in the upload file.
For the eagle eyed viewers - you’d see that I used a JobNum in the Assembly Seq column. Bad spreadsheeting on my part.
But your advice was perfect, and that’s exactly how I found the issue.
Thank you very much.
