There shouldn't be any license codes for Sonic if you run the automated
install which is all that is needed at 99.9% of sites.
If you have purchased any modules or add-ons that require sonic it should
have been sent to you. Some of the things that require it are Multi-Company,
Customer Connect and Supplier Connect for the most common ones.
If you don't have Sonic, then you should be able to call your CAM and they
can likely just get a copy sent to you.
and no, I am not a partner, but I am a former employee turned customer.
Ned
Ned
----- Original Message -----
To: <vantage@yahoogroups.com>
Sent: Tuesday, March 17, 2009 11:12 PM
Subject: [Vantage] Re: Do Inter Trade Via Sonic
> Are you a partner?do you konw how to get the lic code?
> many thanks
> --- In vantage@yahoogroups.com, "Ned" <TechnoBabbly@...> wrote:
>> From OpenEdge?
>> There should be a totally seperate CD for Sonic, and then once you
>> install
>> it you need to make sure you run the updateMQ.bat file, and then actually
>> start the container and have the container running. There is a shortcut
>> for
>> that in the SonicMQ Start Menu group.
>> From: "mintokmint" <mintokmint@...>
>> Sent: Monday, March 16, 2009 9:28 PM
>> >I just installed it from OpenEdge is that enough?
>> > --- In vantage@yahoogroups.com, "Brian W. Spolarich " <bspolarich@>
>> > wrote:
>> >> Do you have SonicMQ installed and the SonicMQ container running?
>> >> -bws
>> >> Brian W. Spolarich ~ Manager, Information Services ~ Advanced Photonix
>> >> Picometrix
>> >> bspolarich@ ~ 734-864-5618 ~
>> >> www.advancedphotonix.com
>> >> From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On
>> >> Behalf
>> >> Of mintokmint
>> >> Sent: Sunday, March 15, 2009 1:25 AM
>> >> To: vantage@yahoogroups.com
>> >> and i check \MultiCompany.log
>> >> Multi-Company Process - Starting Sonic Session (TCP://localhost:2506)
>> >> Multi-Company Process - Sonic Session Failure
>> >> and another Question is when i connect to the Sonic Management Console
>> >> what is the user name and Password by default?
>> >> --- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ,
>> >> "mintokmint" <mintokmint@> wrote:
>> >> > Vantage Ver 803.400
>> >> > Sonic MQ Ver 6.1
>> >> > I want to do Inter Trade between Company A and Company B.
>> >> > Company A send a PO(Suplier is B Inter Trade selected) then run PO
>> >> Suggesstion. But I can't received the PO in Company B (Incoming
>> >> InterCompany PO Suggestion).
>> >> > I have the MultiCompany Scheduled task for both Company.
>> >> > Is there anything I didn't do?
>> >> > any advise?
>> >> > many thanks.
>> >> [Non-text portions of this message have been removed]
>> > Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must
>> > have already linked your email address to a yahoo id to enable
>> > access. )
>> > (1) To access the Files Section of our Yahoo!Group for Report Builder
>> > and
>> > Crystal Reports and other 'goodies', please goto:
>> > http://groups.yahoo.com/group/vantage/files/.
>> > (2) To search through old msg's goto:
>> > http://groups.yahoo.com/group/vantage/messages
>> > (3) To view links to Vendors that provide Vantage services goto:
>> > http://groups.yahoo.com/group/vantage/linksYahoo! Groups Links
> have already linked your email address to a yahoo id to enable access. )
> (1) To access the Files Section of our Yahoo!Group for Report Builder and
