Does the Do Not Ship Before field have any functionality in the system or is it reference only?
It appears in the following tablesâŚ
(Thought that might help)
EDIT: See this for the Schema as a Help file.
I know the OrderAlloc BO method CheckDates() will throw just a Warning not an Exception if DoNotShipBeforeDate or DoNotShipAfterDate are outside the DateTime.Now Window
Warning: you are processing one or more releases outside of their Do Not Ship Before/After Date.
I would assume it would CheckDates during PackOut or somewhere within Shipping.
Just tested it, it doesnât. Of course it doesnât why wouldnât it LOL!
It might only be used then on Order Alloc Entry not even sure what that Form is⌠Ran a used by on the Method looks like the only place in the Entire Epicor Directory I found it in was:
- OrderAllocAdapter
- OrderAllocEntry
Thatâs ok iâll build a BPM and post it here in case anyone else runs into this.
Fires on POFindBuffer in CustShip that way when it matches the row to whatâs on the order we can shoot that down.
foreach(var row in ttPackOut.Where(x => x.SysRowID == rowident))
// Get the order line detail and see if there is a do not ship before or after
var ord = Db.OrderDtl.With(LockHint.NoLock).Where(x => x.Company == row.Company && x.OrderNum == row.OrderNum && x.OrderLine == row.OrderLine).FirstOrDefault();
if(ord != null && (ord.DoNotShipBeforeDate != null || ord.DoNotShipAfterDate != null))
// Check if it has a do not ship before
if(ord.DoNotShipBeforeDate > this.BaqConstants.Today)
found = 0;
rowident = Guid.Empty;
throw new Ice.BLException($"Order {ord.OrderNum} line {ord.OrderLine} is not to ship before {((DateTime)ord.DoNotShipBeforeDate).ToString("MM/dd/yyyy")}. Do not pack this out!");
// Check if it has a do not ship after
if(ord.DoNotShipAfterDate < this.BaqConstants.Today)
found = 0;
throw new Ice.BLException($"Order {ord.OrderNum} line {ord.OrderLine} is not to ship after {((DateTime)ord.DoNotShipAfterDate).ToString("MM/dd/yyyy")}. Please contact customer service.");
I know this topic has been resolved, but I am curious as to where I can find this field. Can it be modified from Order Entry?
Yes I believe itâs on the line and the release. Not 100% if itâs actually exposed in the UI though. Weâve been customized so long now I couldnât tell you what is real and what isnât off the top of my head lol
Just curious here.
Can we drop the â!= nullâ from the If statement expressions?
C# typically only will let you if its a boolean. One thing people do use instead often is.
if (string.IsNullOrEmpty(variable)) { }
No because I am using âordâ to evaluate other values and if I donât check if âordâ is null first I will get instance of an object exceptions trying to get to the properties.
@jgiese.wci
I know this is old⌠but I was wondering how the DoNotShipBeforeDate is initially being set.
It doesnât look like anything native does that, are you using a BPM and if so, how are you determining the value?
Our Service reps set it manually when required
To my knowledge this field is for orders coming in through EDI, where customers give the date in their POs⌠There is also a DoNotShipAfterDate. We use this field to record the CancelAfterDate given by one of our customers in their PO sent through EDI.
