Do you Use Internal Part Cross Reference?
I am curious how you all use the Internal Part Cross Reference. We are considering using it to document the many ways in which a product can be identified.
For example, a tube of grease is stored in Epicor as part number GAK-12345. The product may also have a unique product name, SKU/UPC, or other identifying batch information. We store the part in Epicor with GAK-12345, as that is how the customer calls out the requirement for this product. The customer doesn’t care what kind of grease we use, as long as it conforms to GAK-12345.
Looking at the tube of grease, GAK-12345 is in fine print at the bottom. There could be multiple tubes of grease that conform to GAK-12345, and we can use any of them for this customer. That means that we could use different products for the same part number.
We may have 4 tubes of grease on the shelf all with the same GAK-12345, and each with a unique SKU/UPC, and product name. We track these tubes with lot numbers and track their expiration date by lot.
I want to record all the packages of grease in Epicor so we can keep track of expiration dates more easily, and so we can tell when a particular grease is in stock or out.
At first I looked in to Alternate Parts for this functionality, but it seems more like I should be using Internal Part Cross Reference. What do you all think? How should I set this up?
Thanks!
Nate
Hi Nate
My experience with supplier cross reference is here. I know you’re after doing internal part xref but it may highlight the scale of testing required and definitely make sure you can track down the root cause. In my case though the data was valid:
I am considering using internal part cross reference to help give some parts a user-friendly name.My goal would be to add internal part cross references so that the user can type in a common keyword to find the actual part they need to add. Here are some examples I am considering:
'A-A-56032D'	ink, epoxy, a-a-56032, white
'WD40'	        oil, lube, lubrication, wd40
'VVL-800'	    MIL-PRF-32033, TECTYL 900, VVL-800C, Oil
'MIL-I-43553'	ink, epoxy, a-a-56032, black
'A-A-208WHT'	AA-208, A-A-208WHT,  AA-208WHT, ink, 1250, white
Using the example above, I should be able to type in “ink” as the part number and get a list of all the parts with an internal part xref that includes “ink”. This seems like it would make things easier to search, and give the user more certainty about the part numbers they choose.
What do you think? Am I setting myself up for a future headache? Do you use internal part xref like this?
Thanks for your time!
Nate
Have you looked at Manufacturer Part for this? You can set up part X in your part master and then tie all of the different manufacturer part numbers to it. So if Spacely Sprockets makes it under 123 and Cogswell Cogs make it under 098, you can see that your requirement for part X can be relieved by 123 or 098.
I am considering using that in conjunction. In the cases I listed in my example data, none of those are actual product numbers that we use to order from the manufacturer. Some are specifications that can be applied to more than one product. In the cases where we have multiple manufacturers for a part/product, then I would love to get their part numbers in our system.
Thank you!
