DocStar - Download File via Kinetic Functions Library
Hello!
Does anyone have experience writing custom code to download a file from DocStar using Ice.XFileRef’s XFileRefNum value?
I am working on an external app that will allow users to download files based on a custom search.
I found the below articles, but they are from awhile ago, and I am not sure how to translate the code into a function library, espcially since the WCFServiceSupport was deprecated (from my understanding).
Any guidance would be greatly apprecaited, thank you!
https://www.epiusers.help/t/download-documents-from-docstart/116054
https://www.epiusers.help/t/auto-downloading-ecm-attachments/93164
https://www.epiusers.help/t/how-to-call-docstardownload-attachment/76297/7
I would look at this thread for a start.
Thank you, Greg! I ended up using the Epicor REST API’s Ice.BO.AttachmentSvc/DocStarDownloadFile as well and it worked perfectly!
Hello, Rob -
I’m having a ‘time’ trying to get the REST-kinetic call to work - I’m passing both parameters (xFileRefNum and metadata), but trace shows only xFileRefnum is being passed. I’m on 2025.2.4 using app studio. Could this be a data view issue?
Thanks for any 2 cents you can pass along, and thanks.
