THANK YOU THANK YOU THANK YOU
Just what I was looking for. --- In
vantage@yahoogroups.com, "Michael McWilliams" <mmcwilliams22@...>
wrote:
>right
> I did not realize you meant after you open up the documents. You
> can attatch documents to an operation through job entry. Just
> click on it in the tree view and choose add attatchment. It willlicense
> then show a list when you open up the documents.
> --- In vantage@yahoogroups.com, "Lynn" <lynn.khalife@> wrote:
> > Ours works also upon choosing an operation. We also have
> forstart
> > Document Management for V8.03.404. Like Michael wrote, I don't
> know
> > of anything special that we did to get it to work.
> > Lynn
> > --- In vantage@yahoogroups.com, Mark Wagner <mjfw2003@> wrote:
> > > The bubble is just a reference to a particular place on a CAD
> > drawing. If you want you can attach drawings on the part master
> and
> > then view the attachment on the floor. Jjust open up MES and it
> will
> > take you to part tracker where you can open up the attachment on
> the
> > part record
> > > --- On Mon, 11/3/08, Michael McWilliams <mmcwilliams22@> wrote:
> > > From: Michael McWilliams <mmcwilliams22@>
> > > Subject: [Vantage] Re: Document Maintenance in MES
> > > To: vantage@yahoogroups.com
> > > Date: Monday, November 3, 2008, 11:58 AM
> > > There is a button that says documents on it when you go to
> > > production activity. It is greyed out until after you choosewith
> your
> > > operation in the drop down box. I am not sure but there may be
> > > licensing required to use that funcion. It works on our end
> > > nothing special configured that I know of. We do have docis
> > > management & advance doc licenses though.
> > > --- In vantage@yahoogroups .com, "Lynn" <lynn.khalife@ ...>
> wrote:
> > > > I don't know what you mean by a Documents bubble.
> > > > Are you trying to program the blank MES buttons to do things
> like
> > > > a Job Traveler or other reports?
> > > > Lynn
> > > > --- In vantage@yahoogroups .com, "jimlmm24521" <jimlmm24521@
> > wrote:
> > > > > We would like to attach documents for shop floor employees
> to
> > > access
> > > > > in MES, but when I open the Documents bubble, everything
> > > grayedthat
> > > > > out. I have nothing to use. Is there something special
> I
> > > need
> > > > > to do / have in order to use this??
