FYI,
I went up the food chain at Epicor and did find someone who could
supply the spreadsheets with the Schemas changes. The bummer is,
there are 3 different spreadsheets that I'm going to have to
combine. 6.1 to 8, 8 to 8.03, 8.03 to 8.03.400. Has anyone done
something similar? Or is there some other list of the major
structural changes to the DB?
Brian Stenglein
--- In vantage@yahoogroups.com, "Brian Stenglein" <bstenglein@...>
Brian Stenglein
wrote:
>asked
> When I upgraded from 5.0 to 6.1 Epicor had a spreadsheet that
> documented the changes in DB structure through those versions. I
> support if there was a similar tool for going from 6.1 to8.03.400.
> The tech I talked to suggested review ALL of the patch changelists. I
> just about fell off my chair.RepSplit
> I'm running into several significant changes so far and I've only
> looked at a few reports. For example, the ShipHead table no longer
> contains the OrderNum field. In the Invoice Detail table the
> and RepRate fields are no longer arrays. They are each broken outinto
> 5 fields. The Part Table no longer contains costs, instead thereis a
> new Part Cost table.kinds
> Does anyone know of documentation that would cover all of these
> of changes to the data structure from 6.1 to 8.03.400?
> Thanks,
> Brian Stenglein
