DOS command
Thank you.
----- Original Message -----
To: <vantage@yahoogroups.com>
Sent: Thursday, April 11, 2002 6:56 AM
Subject: [Vantage] RE: DOS command
> On Tue, 09 Apr 2002 22:35:36 Mike Tonoyan Wrote:
> > Does any body familiar with DOS commands know how to get the same
> > results in windows as the following:
> > DIR *.TXT /O /B > TEST.TXT ?
> Mike, Unfortunately there is no way in Windows to print a directory
> listing without using a dos window (command prompt) and entering
> the DOS command. This function is available if you are using Outlook
> (Not Outlook Express); Try this:
> 1. In Microsoft Outlook, click Other Shortcuts on the shortcut bar.
> 2. In the Look in box, click File System, and then click My Computer.
> NOTE: You may want to view the folder list. (This differs slightly
> for different versions of Outlook)
> 3. Click the folder that you want to list.
> 4. On the File menu, click Print, click Table Style. Outlook prints
> a list of every file that is in that folder and includes the file
> size, date, and other attributes.
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must
> (1) To access the Files Section of our Yahoo!Group for Report Builder and
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
Mike Tonoyan / All American Products Co.
Thanks Michael,
Good old DOS, life was lot easier then.
Mike Tonoyan
Sent: Wednesday, April 10, 2002 10:14 PM
Subject: RE: [Vantage] DOS command
> Mike,
> I didn't see any responses to this post ... so here goes ...
> I presume you don't want to run a .CMD or .BAT to do this, so one way is
to
> use a Script. I have been looking for an excuse to read about Windows
> Script. Turns out it can run a number of different script types (eg
> VBScript, Java Script), we have all probably seen the .vbs extension that
we
> associate with viruses (eg HotChick.jpg.vbs). I had to allow Norton to
run
> my test script !
> After a bit of looking around for functions and methods on
> msdn.microsoft.com, I believe something like the following will do what
you
> are looking for :-
> ----- Put these in a .vbs file and run -----
> Const ForReading = 1, ForWriting = 2
> Dim fso, f1, f2, f3, f4
> Set fso = CreateObject("Scripting.FileSystemObject")
> Set f1 = fso.GetFolder("h:\temp")
> Set f4 = fso.OpenTextFile("h:\text.txt", ForWriting, True)
> Set f3 = f1.Files
> For Each f2 in f3
> If f2.type = "Text Document" Then
> WScript.Echo f2.name
> f4.WriteLine f2.name
> End If
> Next
> ----- End of Text file -----
> There are lots of other useful things you can do as well, like
> creating/modifying Active Directory object, Registry keys, creating
> printers.
> Don't ask me questions though, I know nothing more than I have learnt in
the
> past hour. It looks like the sort of topic that you need a week and a
good
> book to become familiar with. I'm sure Thad could do much better with his
> programming background.
> Regards
> Michael
> -----Original Message-----
