Drop Ship Schema
Does anyone know what report style has the DropShip Schema? I am trying to modify the fields going out, but I cannot find the correct report. This is an ASN EDI report. However, when I pull up the report data definition there is no DropShipDtl table.
Where are you initiating this from what Form/UI element screen?
So this is strange. It was set up prior to my arrival here. Whatever kicks it off is tied to DMT. The user DMT’s a tracking number into the dropship packslip and that kicks off the files that get outputted to a folder where TIE picks up.
What is the DMT it is using? That will tell you which schema it should be tied to.
Never Mind. Just found it. It was tied to custom code within a BPM.
The problem I am having is that the schema only shows 105 field values but the actual file spits out 107.
