Dan,
As was mentioned in an earlier reply, you need to weigh cost with your
comfort level. We are using this same solution from Qwest and decided on
the simple and inexpensive route. The 678 is a capable router - it does
NAT, PAT, DHCP, etc - however, it does not come with the Cisco IOS and the
ability to add the firewall component. For this reason, we decided to use
Proxy Server that comes with SBS 4.5 for our firewall. I realize that Proxy
is much less powerful than other solutions, but it's easy to set up and you
already own it. After we applied service pack 1, it has been very effective
for us.
On the other hand, if you don't trust Proxy Server, the 678 does some
limited IP filtering. I think you can apply up to 10 filters. You could
set up the 678 to do DHCP and NAT and then apply filters as needed. But
then, you'd miss the fun GUI wizards that come with Proxy... <grin>
Hope this helps,
Dave Bell
Sent: Monday, August 06, 2001 10:28 AM
Subject: [Vantage] DSL & firewalls
We are installing a DSL line in a week. Qwest is supplying a Cisco 678
router and tells me no firewall is necessary. My ISP tells me that a
firewall is absolutely essential. Will the router provide sufficient
protection? We are running SBS 4.5, what is the best way to restrict access
with the new connection? Using Proxy or a software firewall?
Dan Shallbetter
States Electric Mfg.
for us.
Hope this helps,
Dave Bell
Dan Shallbetter
