We recently updated to .700.30 (from .700.21 I think) and since then we cannot duplicate quotes. When we do, we get the following error. HOWEVER, if I copy the DB and put it into PILOT, without any change, there is no error. Duplicate works fine.
I’ve disabled form customization and all BPMs that touch anything Quote related, but still nothing.
Why would it work in PILOT, but not in LIVE? Same dot release, same license, and a copy of the same database from minutes ago…
Any ideas?
System Information
AppServer Connection: net.tcp://EP10APP2/EP102700_LIVE
Form Name: Opportunity/Quote Entry
Customization Name:
Menu ID: EQMT2010
Software Version: 10.2.700.30
Application Error
Error Detail
##!Correlation ID:##! 4e07905f-5baf-4d7d-ac4c-c0652d0b8567
##!Message:##! Unable to cast object of type ‘System.Func4[Erp.ErpContext,System.String,System.String,Erp.Services.BO.QuoteSvc+RoleCdResult]' to type 'System.Func4[Erp.ErpContext,System.String,System.String,Erp.Triggers.QuoteHed.WriteTrigger+RoleCdResult]’.
##!Program:##! Epicor.ServiceModel.dll
##!Method:##! ShouldRethrowNonRetryableException
Client Stack Trace
at Epicor.ServiceModel.Channels.ImplBase`1.ShouldRethrowNonRetryableException(Exception ex, DataSet dataSets)
at Erp.Proxy.BO.QuoteImpl.DuplicateQuote(Int32 sourceQuote, String sourceLines, Boolean mtlCosts, Boolean opStds)
at Erp.Adapters.QuoteAdapter.DuplicateQuote(Int32 sourceQuote, String sourceLines, Boolean mtlCosts, Boolean opStds)
Launching “duplicate quote” function… that works, then we select the desired lines, then we get the error after the lines are selected and ready to duplicate.
