Duplicate record error on new quote? 10.1.600.4
Well, Mark and I found something else interesting when we tried to duplicate a quote. We get this error. Does anyone know what this means? Or more importantly an idea for a workaround? We have a theory that if we can get the first one to go that we will be fine.
Application Error
Error Detail
Message: An error occurred while updating the entries. See the inner exception for details.
Inner Exception Message: Cannot insert duplicate key row in object 'Erp.QSalesRP' with unique index 'IX_QSalesRP'. The duplicate key value is (RAPAT, 1000000, 4221).
The statement has been terminated.
Program: Epicor.ServiceModel.dll
Method: ShouldRethrowNonRetryableException
Client Stack Trace
   at System.Data.Mapping.Update.Internal.UpdateTranslator.Update(IEntityStateManager stateManager, IEntityAdapter adapter)
   at System.Data.Objects.ObjectContext.SaveChanges(SaveOptions options)
   at Ice.IceDataContext.SaveChanges(SaveOptions options) in c:\_Releases\ICE\3.1.600.0\Source\Framework\Epicor.System\Data\IceDataContext.cs:line 352
   at Ice.IceDataContext.SaveChangesIfRowHasBeenChanged[TLinqRow](TLinqRow row) in c:\_Releases\ICE\3.1.600.0\Source\Framework\Epicor.System\Data\IceDataContext.cs:line 537
   at Ice.Triggers.TriggerQueue.RunWriteTriggerInNewLevel(IceDataContext context, LinqRow modifiedRecord, LinqRow originalRecord, Boolean forAddedRow) in c:\_Releases\ICE\3.1.600.0\Source\Framework\Epicor.System\Triggers\TriggerQueue.cs:line 174
   at Ice.Triggers.TriggerQueue.<>c__DisplayClass11_0.<RunWriteTrigger>b__1() in c:\_Releases\ICE\3.1.600.0\Source\Framework\Epicor.System\Triggers\TriggerQueue.cs:line 148
   at Ice.Triggers.TriggerQueue.RunAtNewLevel(Func`1 buildTriggerRunState, Action action) in c:\_Releases\ICE\3.1.600.0\Source\Framework\Epicor.System\Triggers\TriggerQueue.cs:line 501
   at Ice.Triggers.TriggerQueue.RunTriggers(IceDataContext context) in c:\_Releases\ICE\3.1.600.0\Source\Framework\Epicor.System\Triggers\TriggerQueue.cs:line 83
   at Ice.IceDataContext.RunUntilAllTriggersHaveExecuted() in c:\_Releases\ICE\3.1.600.0\Source\Framework\Epicor.System\Data\IceDataContext.cs:line 566
   at Ice.IceDataContext.Validate[TLinqRow](TLinqRow row) in c:\_Releases\ICE\3.1.600.0\Source\Framework\Epicor.System\Data\IceDataContext.cs:line 323
   at Erp.Triggers.QuoteHed.WriteTrigger.createQSalesRP(QuoteHed& QuoteHed, Boolean& SetToPrimary, String vNewRoleCode) in c:\_Releases\ERP\RL10.1.600.0\Source\Server\Db\Triggers\QuoteHed\Write.cs:line 1848
   at Erp.Triggers.QuoteHed.WriteTrigger.write(QuoteHed QuoteHed, QuoteHed OldQuoteHed) in c:\_Releases\ERP\RL10.1.600.0\Source\Server\Db\Triggers\QuoteHed\Write.cs:line 930
   at Erp.Triggers.QuoteHed.WriteTrigger.Write(QuoteHed QuoteHed, QuoteHed OldQuoteHed) in c:\_Releases\ERP\RL10.1.600.0\Source\Server\Db\Triggers\QuoteHed\Write.cs:line 169
   at Ice.Triggers.TriggerQueue.ExecuteWriteTrigger(IceDataContext context, LinqRow modifiedRecord, LinqRow originalRecord) in c:\_Releases\ICE\3.1.600.0\Source\Framework\Epicor.System\Triggers\TriggerQueue.cs:line 296
   at Ice.Triggers.TriggerQueue.RunWriteTriggerInNewLevel(IceDataContext context, LinqRow modifiedRecord, LinqRow originalRecord, Boolean forAddedRow) in c:\_Releases\ICE\3.1.600.0\Source\Framework\Epicor.System\Triggers\TriggerQueue.cs:line 157
   at Erp.Services.BO.QuoteSvc.DuplicateQuote(Int32 sourceQuote, String sourceLines, Boolean mtlCosts, Boolean opStds) in C:\_Releases\ERP\UD10.1.600.4\Source\Server\Services\BO\Quote\Quote.cs:line 12327
   at Epicor.Customization.Bpm.BO10F10BBEE93F403BA54D024FFBF2387B.DuplicateQuoteImpl.ExecuteBase(DuplicateQuoteParameters parameters)
   at Epicor.Customization.Bpm.MethodCustomizationBase2`3.RunDirectives(TParam parameters) in c:\_Releases\ICE\3.1.600.0\Source\Server\Internal\Lib\Epicor.Customization.Bpm\MethodCustomizationBase2.cs:line 215
   at Epicor.Customization.Bpm.CustomizationBase2`3.Execute(TParam parameters) in c:\_Releases\ICE\3.1.600.0\Source\Server\Internal\Lib\Epicor.Customization.Bpm\CustomizationBase2.cs:line 71
   at Epicor.Customization.Bpm.BO10F10BBEE93F403BA54D024FFBF2387B.QuoteSvcCustomization.DuplicateQuote(Int32 sourceQuote, String sourceLines, Boolean mtlCosts, Boolean opStds)
   at Erp.Services.BO.QuoteSvcFacade.DuplicateQuote(Int32 sourceQuote, String sourceLines, Boolean mtlCosts, Boolean opStds) in C:\_Releases\ERP\UD10.1.600.4\Source\Server\Services\BO\Quote\QuoteSvcFacade.cs:line 965
   at SyncInvokeDuplicateQuote(Object , Object[] , Object[] )
   at System.ServiceModel.Dispatcher.SyncMethodInvoker.Invoke(Object instance, Object[] inputs, Object[]& outputs)
   at Epicor.Hosting.OperationBoundInvoker.InnerInvoke(Object instance, Func`2 func) in c:\_Releases\ICE\3.1.600.0\Source\Framework\Epicor.System\Hosting\OperationBoundInvoker.cs:line 59
   at Epicor.Hosting.OperationBoundInvoker.Invoke(Object instance, Func`2 func) in c:\_Releases\ICE\3.1.600.0\Source\Framework\Epicor.System\Hosting\OperationBoundInvoker.cs:line 47
   at Epicor.Hosting.Wcf.EpiOperationInvoker.Invoke(Object instance, Object[] inputs, Object[]& outputs) in c:\_Releases\ICE\3.1.600.0\Source\Framework\Epicor.System\Hosting\Wcf\EpiOperationInvoker.cs:line 23
   at System.ServiceModel.Dispatcher.DispatchOperationRuntime.InvokeBegin(MessageRpc& rpc)
   at System.ServiceModel.Dispatcher.ImmutableDispatchRuntime.ProcessMessage5(MessageRpc& rpc)
   at System.ServiceModel.Dispatcher.ImmutableDispatchRuntime.ProcessMessage11(MessageRpc& rpc)
   at System.ServiceModel.Dispatcher.MessageRpc.Process(Boolean isOperationContextSet)
Inner Trace:
:   at System.Data.SqlClient.SqlConnection.OnError(SqlException exception, Boolean breakConnection, Action`1 wrapCloseInAction)
   at System.Data.SqlClient.TdsParser.ThrowExceptionAndWarning(TdsParserStateObject stateObj, Boolean callerHasConnectionLock, Boolean asyncClose)
   at System.Data.SqlClient.TdsParser.TryRun(RunBehavior runBehavior, SqlCommand cmdHandler, SqlDataReader dataStream, BulkCopySimpleResultSet bulkCopyHandler, TdsParserStateObject stateObj, Boolean& dataReady)
   at System.Data.SqlClient.SqlDataReader.TryConsumeMetaData()
   at System.Data.SqlClient.SqlDataReader.get_MetaData()
   at System.Data.SqlClient.SqlCommand.FinishExecuteReader(SqlDataReader ds, RunBehavior runBehavior, String resetOptionsString, Boolean isInternal, Boolean forDescribeParameterEncryption)
   at System.Data.SqlClient.SqlCommand.RunExecuteReaderTds(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, Boolean async, Int32 timeout, Task& task, Boolean asyncWrite, Boolean inRetry, SqlDataReader ds, Boolean describeParameterEncryptionRequest)
   at System.Data.SqlClient.SqlCommand.RunExecuteReader(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, String method, TaskCompletionSource`1 completion, Int32 timeout, Task& task, Boolean& usedCache, Boolean asyncWrite, Boolean inRetry)
   at System.Data.SqlClient.SqlCommand.RunExecuteReader(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, String method)
   at System.Data.SqlClient.SqlCommand.ExecuteReader(CommandBehavior behavior, String method)
   at System.Data.SqlClient.SqlCommand.ExecuteReader(CommandBehavior behavior)
   at System.Data.Mapping.Update.Internal.DynamicUpdateCommand.Execute(UpdateTranslator translator, EntityConnection connection, Dictionary`2 identifierValues, List`1 generatedValues)
   at Epicor.ServiceModel.Channels.ImplBase`1.ShouldRethrowNonRetryableException(Exception ex, DataSet[] dataSets)
   at Erp.Proxy.BO.QuoteImpl.DuplicateQuote(Int32 sourceQuote, String sourceLines, Boolean mtlCosts, Boolean opStds)
   at Erp.Adapters.QuoteAdapter.DuplicateQuote(Int32 sourceQuote, String sourceLines, Boolean mtlCosts, Boolean opStds)
Inner Exception
You can use the Administration Console to create the DEMO database. Under database server management and right-click on the name of your SQL server and select Add Demo Database
Haha, we figured it out. There was a Data directive BPM running to set the salesperson based on who was logged in (I think, I didn’t make it). I disabled it, and now we can create quotes.
Thanks everyone for your help.
…And we often roll our eyes when Epicor Support asks about BPM’s and Customization’s…
…or at least I have…
