Vic,
Thanks. Can't believe I haven't run across this before.
Kent Reardon
315-575-8067
CC: k-reardon@...
Subject: RE: [Vantage] DWBAR 39
Date: Thu, 12 Jul 2012 09:18:45 -0400
Check out "Special Barcode Characters.PDF" in http://tech.groups.yahoo.com/group/vantage/files/Barcoding/ In Crystal Reports on that field, you'll need to create a formula, use the REPLACE() function and replace any "_" with a "%O". That's from memory, but double check. And then use that formula in place of the current barcoded Part Number text object in CR. Remember to encapsulate the part number with asterisks. So if your Part Number was: "123_456" Your formula would look something like "*" + REPLACE({Part.Partnum}, "_", "%O") + "*"and it would effectively look like: "*123%O456*" Flip the font of the formula field once you drag it onto your report to DWBar and then it should scan fine. From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of reardon_kent
Sent: Thursday, July 12, 2012 9:09 AM
Subject: [Vantage] DWBAR 39
Ran into an issue with Bar Coding a part number with an imbedded underscored,using Dataworks Bar 39. Instead of bar coding the underscore as part of the text string, a '_' appears within the bar code. Has anyone run into this and found a solution?No virus found in this message.
Checked by AVG - www.avg.com
Version: 2012.0.2195 / Virus Database: 2437/5127 - Release Date: 07/12/12No virus found in this message.
Kent Reardon
315-575-8067
CC: k-reardon@...
