Thank you,
I'll try it out !
Guess I had to go longhand without having good docs or clear info from Epicor support on this one.
Appreciate your help,
Dave
Thank you,
I'll try it out !
Dave
We are on Version 10.1.400.11 in our production environment. We also have a separate 10.1 virtual test environment set up. Our dilemma is to refresh our test database we have to restore from a backup (which is no problem) then we need to modify the .ice tables to point to the test environment. This is a cumbersome process which takes time and is susceptible to errors. Is there a migration/copy tool available that can automate this process? We want to maintain this test environment to validate point releases and to test system features we have questions about; having up to date data makes the environment much more valuable/realistic.
Keith Mailloux
On Wed, Aug 17, 2016 at 3:24 PM, Keith Mailloux keith.mailloux@... [vantage] <vantage@yahoogroups.com> wrote:Â<div> <p>
Â
Â
Â
Keith Mailloux
Â
</div> <div style="color:#fff;min-height:0;"></div>
Hi Jose,
I work with
Keith at Ferguson Perforating.
Our Scenario
here:
A live physical server called “EPICORSERVERâ€.
A development/test virtual
server called “DEV-V-EPIC101†which has a snapshot of live data on it.
What I have done in the past to
refresh the Test servers data with live data is:
Restore a full SQL
backup of live database onto dev server (both databases named EPICOR10)
Update via SSMS, Ice schema table
entries which have entries for EPICORSERVER, either changing the entries to
DEV-V-EPIC101 or deleting the row depending on the table
I realize direct editing of
these tables is dangerous and would only do it on a Test server.
This updating did work for us,
we are just wondering if there was something more automatic ?
I was told by Epicor Support
that what we are looking for does not exist.
Dave
Beberman
ERP Manager
On Thu, Aug 18, 2016 at 9:35 AM, dbeberman@... [vantage] <vantage@yahoogroups.com> wrote:Â<div> <p><font face="Times New Roman" size="3">
Hi Jose,
I work with
Keith at Ferguson Perforating.Our Scenario
here:               A live physical server called “EPICORSERVERâ€.
server called “DEV-V-EPIC101†which has a snapshot of live data on it.               What I have done in the past to
refresh the Test servers data with live data is:Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Restore a full SQL
backup of live database onto dev server (both databases named EPICOR10)Update via SSMS, Ice schema table
DEV-V-EPIC101 or deleting the row depending on the table               I realize direct editing of
these tables is dangerous and would only do it on a Test server.               This updating did work for us,
we are just wondering if there was something more automatic ?               I was told by Epicor Support
that what we are looking for does not exist.Thanks,
Dave
BebermanERP Manager
The tables
affected:
Ice.ExtServiceRegistration
- Delete All rows
Ice.SysAgent
- Delete All rows
Ice.SysAgentSched
- Delete All rows
Ice.SysCompany
- Update the single row with
UPDATE A
EntSearchURL = ‘’,
SSRSURL = ‘HTTP://DEV-V-EPIC101/EpiSSRSPortal’
SMTPServer = ‘’,
SMTPPort = 0
FROM EPICOR10.Ice.SysCompany A
Ice.SysConfig
-Delete Search Server row with
DELETE FROM EPICOR10.Ice.SysConfig
WHERE Key1 = ‘ESUrl’
I wanted to
make sure that anything in the DEV environment would not access any live
resources
-Dave
On Thu, Aug 18, 2016 at 10:02 AM, dbeberman@... [vantage] <vantage@yahoogroups.com> wrote:Â<div> <p><font face="Times New Roman" size="3">
The tables
affected:Â
               - Delete All rows
Ice.SysAgent
               - Delete All rows
Ice.SysAgentSched
               - Delete All rows
Ice.SysCompany
               UPDATE A
               EntSearchURL = ‘’,
               SSRSURL = ‘HTTP://DEV-V-EPIC101/ EpiSSRSPortal’
               SMTPServer = ‘’,
               SMTPPort = 0
Ice.SysConfig
WHERE Key1 = ‘ESUrl’Â
I wanted to
resources
-Dave
</div><span class="ygrps-yiv-159677710"> <div style="color:#fff;min-height:0;"></div>
