E10, BPM, Finding Last Record
Thank you Brenda.
Worked like a charm!
On E9 I would use the code:
Find Last Part where.....
for E10 you would think the code would be:
select Part_Row).LastOrDefault();
however, LastOrDefault is not supported.
The Epicor code convertor tells you to do this:
// TODO: LastOrDefault() is not supported. Convert this to FirstOrDefault(). Make sure you specify an
// order by clause that specifies all the key fields in the opposite order so that the first row
// is the last row that would have been retrieved.
How do you specify the order of the fields?
Here is a template I use:
var XXX_Recs = (from XXX_Row in Db.XXX
                where XXX_Row.Company == Session.CompanyID
                && XXX_Row.YYY == ZZZ_Recs.YYY
    orderby XXX_Row.YYY, XXX_Row.YYY
                select XXX_Row).FirstOrDefault();
            var XXXRow = XXX_Recs;
            if (XXX_Recs != null)
               callContextBpmData.CCC = XXX_Recs.YYY;
}          /*** XXX ***/
Brenda
Sent: Wednesday, February 03, 2016 11:19 AM
Subject: [Vantage] E10, BPM, Finding Last Record
