Hello,
I am debugging some code in a method directive that is causing me to bang my head against the wall?
I am working with an Erp.Tablesets.OrderAllocTableset dataset.
I’ve haven’t confirmed but I would expect that OrderAllocTableset is dervived from DataSet.
When testing my method calls in the BL Tester, I can see that a row is returned in OrderAllocDataSet.OrderAlloc.
In my code though, the following LINQ statement seems to indicate that there are no rows in Orderalloc:
from OrderAlloc_Row in OrderAllocDataSet.OrderAlloc select OrderAlloc_Row
Specifical, this foreach loop never triggers the code in the loop.
foreach (var OrderAlloc_iterator in (from OrderAlloc_Row in OrderAllocDataSet.OrderAlloc select OrderAlloc_Row))
This was confusing to me so I thought I would throw a messagebox showing the row count but when I tried this:
OrderAllocListDataSet.OrderAllocList.Rows.Count.ToString()
I got a compile error that said Rows was not defined in OrderAlloc.
I then tried casting it to a DataTable with:
(DataTable)(OrderAllocDataSet.OrderAlloc)).Rows.Count.ToString()
I got a compile error that said I could not do this cast.
I must be missing something.
Any ideas?
Joe Rojas | Director of Information Technology | Mats Inc
dir: 781-573-0291 | cell: 781-408-9278 | fax: 781-232-5191
addr: 179 Campanelli Pkwy | Stoughton | MA | 02072-3734
jrojas@... | www.matsinc.com
Ask us about our clean, green and beautiful matting and flooring
[cid:27994d.png@091922d4.43880459]
This message is intended only for the individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail. Please notify the sender immediately by e-mail if you have received this e-mail by mistake. Please note that any views or opinions presented in this email are solely those of the author and do not necessarily represent those of the company.
Any ideas?
