E10 MES setup and lockdown on windows 8.1
Professional services told me to contact the hardware manufacturer, who pointed me to a Microsoft lockdown tool that only works on the creation on embedded image, which you cant get access to unless you are a manufacturer.  The kiosk mode in windows 8 used under a local user will do exactly what I need but it is not available in a domain. It will only allow a specific program, and it will relaunch it if it is closed. Almost the same as Shell.
 I dont know about your environment but I have had support calls from supervisors saying people could not clock in and all they needed to do was click the one and only mes icon on the desktop...  I built self service kiosks for almost a decade so I am well aware of the options, policies and third party programs but epicor is selling hardware designed to run their software (as a dedicated timeclock) without any reference whatsoever on how do so.  They do not do this with the regular client application, nor the server application, nor most modules.  MES (and the handheld) are more or less undocumented if you want to modify how they run on a client.  Go ahead and try to install the HH on any handheld, good luck unless it is an intermec. I have had it running on an android phone as well as a few other handheld scanners but finding setup information is almost impossible,
Really the only reason I asked instead of doing it myself was that it was a total surprise that e10 would not run on my existing winxp MES station (which look to be exactly the same as my new embedded 8 stations).  I had to get them deployed in 6 hours after getting the runaround for over a week from epicor, all the while thinking I could use the old stations until the new ones were setup correctly.
 I figured this group might have some insight into win8 with MES for E10 but perhaps I will write a setup guide instead.
Anyone have a descent guide on setting up shopfloor MES for E10 on a touchscreen windows 8.1?  I am fumbling through it but there absolutely no help from epicor but a bunch of finger pointing around in a circle.  Considering we bought the hardware from them there should be some sort of setup guide but there isn't.
So far i have them logging in with a domain user and and i have MES autologging in.  Functionally it works OK but users have easy access to most of the settings/charms etc.. and if they kill mes they have to manually restart it.  The Kiosk mode does not seem to work on domain accounts.  Any suggestions?
I kind of have to side with them. Unless you bring in professional services apply policies to those devices “to lock them down” (which would be a weird thing for them to do) the lockdown and setup portion is kind of on each company to deal with. They don’t know and won’t write guides to support every companies ideal setup. If you want it locked down that all starts at the GPOs and then goes up to network level security.
When it comes to re-launching MES just have a shortcut on the desktop to open it back up?  If you wanted to auto relaunch you would need some middleware that is monitoring that process/exe but that seems like overkill. Just get it to a stripped down desktop via GPO bare minimum and one shortcut for mes.
Joshua Giese
CIO
Direct:     920.593.8299
IT Dept:   920.437.6400 Ext. 337
Site ID:    27450-E905702A-SQL64
Wisconsin Converting, Inc.
Sent: Thursday, July 16, 2015 3:00 PM
Subject: [Vantage] E10 MES setup and lockdown on windows 8.1
