I received a one off that lists the same SCRs as below (148182, 158035, 158032) and it did not fix my issue.
Joe Rojas | Director of Information Technology | Mats Inc
dir: 781-573-0291 | cell: 781-408-9278 | fax: 781-232-5191
addr: 179 Campanelli Pkwy | Stoughton | MA | 02072-3734
jrojas@... | www.matsinc.com
Ask us about our clean, green and beautiful matting and flooring
[cid:4d8c16.png@44a9aea6.47a6bfb8]
This message is intended only for the individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail. Please notify the sender immediately by e-mail if you have received this e-mail by mistake. Please note that any views or opinions presented in this email are solely those of the author and do not necessarily represent those of the company.
Sent: Friday, March 20, 2015 12:16 PM
Subject: Re: [Vantage] E10: Product Configurator - Setting Input.Invisible takes long time to process
Joe,
Here are the patch numbers:
RE: One Off of SCRs 158032, 158035, 148182 for 700.4 TT# 3287965ESC
I don't know what all of them do. They were in response to very slow times for the client-side UD methods to fire.
I didn't exhaustively test the the invisible attribute, but I couldn't see any appreciable lag.
I also didn't try the invisible attribute before they applied the patches.
The thing we did see when we went to 700.4 was that all but one of my configurators broke, and it took a while to figure out why. On all but the one, I call a server-side method called "ReadPart" that gets a part record for description, price, etc. In 700.2 I use the full name "UDMethods.ReadPart." On 700.4 I have to drop the "UDMethods." from the method name or the method won't compile.
Hope it helps. Good luck!
Joe Trent
On Fri, Mar 20, 2015 at 7:48 AM, Joe Rojas jrojas@...<mailto:jrojas@...> [vantage] <vantage@yahoogroups.com<mailto:vantage@yahoogroups.com>> wrote:
My bad. :)
I am using the Invisible property. That’s what I get for free handing the code.
There is other code in this OnFieldChanged action but it is definitely the setting of the Invisible property.
If I don’t set any inputs to invisible, the action takes 1 second to run.
It I set one input to invisible, 7 seconds.
2 inputs to invisible, 13 seconds.
7 inputs to invisible, 43 seconds.
There is no code on any actions for the inputs being set to invisible.
We just went from 700.2 to 700.4 yesterday because of other bug fixes with the configurator that we needed.
You mentioned several on-off patches for 700.4, do you have these installed? Maybe one of these patches addresses this issue, which is why you are not seeing it.
dir: 781-573-0291<tel:781-573-0291> | cell: 781-408-9278<tel:781-408-9278> | fax: 781-232-5191<tel:781-232-5191>
jrojas@...<mailto:jrojas@...> | www.matsinc.com<http://www.matsinc.com>
