E10 - Searches Blank Title 136046
In New PO Suggestions, Buyers want the search results sorted by Supplier then by PartNum the by DueDate
In the basic search selection grid, I can only get one column to sort.
I created a BAQ to sort the fields as requested and made the SugNum the "Like" Column on the BAQ Search Tab.
While this works, the Buyer now has to find their BuyerID and select the rows to return...
I built a dashboard to filter the BAQ results buy tracker view control. I go to try and make the dashboard an Advance Search dashboard but SuggPODtl.SugNum is not an available "Like" field
I went to Extended Property Maint and Made sure it is indeed a "Like" field and it is the default get by ID field for the adapter.
Why does this have to be so blasted difficult
any ideas short of making umpteen baq searches - one for each buyer ID.....
bw
