E10 sql query for table & corresponding UD table
Thanks!
Rob Bucek
Production Control Manager
PH: (715) 284-5376 ext 311
Mobile: (715)896-3119
FAX: (715)284-4084
[cid:1.234354861@...]<http://www.dsmfg.com/>
(Click the logo to view our site)<http://www.dsmfg.com/>
Sent: Wednesday, June 17, 2015 4:31 PM
To: Vantage
Subject: Re: [Vantage] Re: E10 sql query for table & corresponding UD table
You can run SELECT * FROM Part (no Erp.) it will use the combined view
Jose C Gomez
Software Engineer
T: 904.469.1524 mobile
E: jose@...<mailto:jose@...>
http://www.josecgomez.com
[Image removed by sender.]<http://www.linkedin.com/in/josecgomez> [Image removed by sender.] <http://www.facebook.com/josegomez> [Image removed by sender.] <http://www.google.com/profiles/jose.gomez> [Image removed by sender.] <http://www.twitter.com/joc85> [Image removed by sender.] <http://www.josecgomez.com/professional-resume/> [Image removed by sender.] <http://www.josecgomez.com/feed/>
On Wed, Jun 17, 2015 at 5:21 PM, jckinneman@...<mailto:jckinneman@...> [vantage] <vantage@yahoogroups.com<mailto:vantage@yahoogroups.com>> wrote:
There is a view that combines the two tables for you. View will have same name as the primary table. View only exists if there is a UD table partner.
Jim Kinneman
Encompass Solutions, Inc
What are folks using out there for syntax if any when you want to look at the part table along with all the UD fields like we used to be able to do it in versions 9 or earlier(other than hammering in every field individually). Just curious.
Select * from Erp.Part doesn't obviously bring in anything from Erp.Part_UD but a select * on two joined tables isn't the method either?
Rob Bucek
FAX: (715)284-4084
Never mind...
select * from Erp.part
inner join Erp.Part_UD on part.SysRowID = Part_UD.ForeignSysRowID
Rob Bucek
FAX: (715)284-4084
Sent: Wednesday, June 17, 2015 4:03 PM
Subject: [Vantage] E10 sql query for table & corresponding UD table
Rob Bucek
FAX: (715)284-4084
Jim Kinneman
You can run SELECT * FROM Part (no Erp.) it will use the combined viewÂ
Jose C Gomez
Software Engineer
On Wed, Jun 17, 2015 at 5:21 PM, jckinneman@... [vantage] <vantage@yahoogroups.com> wrote:
Â
<div>
  <p>There is a view that combines the two tables for you.  View will have same name as the primary table.  View only exists if there is a UD table partner.</p><div><br></div><div>Jim Kinneman</div><div>Encompass Solutions, Inc</div><p></p>
</div>
<div style="color:#fff;min-height:0;"></div>
