This is from the DMT labs and templates directory. I don’t know what version runs on 8.03. I’m Stephen could likely shed more light on this if you needed it.
Greg Payne
REM DMT Script Interface Example
REM
REM This Script provides an example of how to automate the use of the DMT.
REM The DMT supports this functionality from versions 1.0.3.8 onwards
REM The name of the import= argument is the name of the menu item within the GUI
REM Instead of Start /w, the /w can be removed which will allow multiple items to start at the same time
REM A Complete Log, Error Log and Error text log will be created as automatically and if it already exists will be replaced
REM
@ECHO OFF
SET SERVER=192.168.232.129
SET PORT=9011
ECHO Remove Parts
start /w dmt.exe -user manager -pass manager -server %SERVER% -port %PORT% -import="Part" -source="C:\Users\Stephen Edginton\Documents\DMT\DMT Inventory Templates\Part.csv"
-delete
IF %ERRORLEVEL% == 1 ECHO Some Errors While removing parts - review log
ECHO Imports Parts
-add -update
IF %ERRORLEVEL% == 1 GOTO ERROR
ECHO ..OK
ECHO Import Part Plant
start /w dmt.exe -user manager -pass manager -server %SERVER% -port %PORT% -import="Part Plant" -source="C:\Users\Stephen Edginton\Documents\DMT\DMT Inventory
Templates\Part_Plant.csv" -add -update
ECHO ..OK
GOTO END
:ERROR
ECHO Error Occurred Aborted
GOTO END
:END
ECHO Finished
PAUSE
On Behalf Of William King
Sent: Thursday, October 17, 2013 3:55 PM
To: EPICOR UG (vantage@yahoogroups.com)
Subject: [Vantage] E8.03.409C: Command Line call for DMT
Is anyone aware on how to call the Epicor 8.03.409C DMT from command line?
William R. King
IT Analyst
Topura America Fastener, Inc.
CONFIDENTIALITY NOTICE
The information contained in this communication, including attachments, is privileged and confidential. It is intended only for the exclusive use of the addressee. If the reader of this message is not the intended recipient, or the employee or agent responsible
for delivering it to the intended recipient, you are hereby notified that any dissemination, distribution or copying of this communication is strictly prohibited. If you have received this communication in error, please notify us at 727-578-6280 and immediately
delete the communication.
"This (document/presentation) may contain technical data as defined in the International Traffic In Arms Regulations (ITAR) 22 CFR 120.10. Export of this material is restricted by the Arms Export Control Act (22 U.S.C. 2751 et seq.) and may not be exported
to foreign persons without prior approval form the U.S. Department of State."
