That worked. The PA.GetQuoteDtlPARows gave me the same tables, so I create the BPM PP on the BO. I also needed to change the code on the PartAdvisor XML. I needed to point to the TT tables.
public static void InitializeCustomCode()
SetExtendedProperties();
private static void SetExtendedProperties()
// Begin Wizard Added EpiDataView Initialization
EpiDataView edvQuoteView = ((EpiDataView)(Script.oTrans.EpiDataViews["QuoteView"]));
// End Wizard Added EpiDataView Initialization
// Begin Wizard Added Conditional Block
if (edvQuoteView.dataView.Table.Columns.Contains("ShortChar01"))
// Begin Wizard Added ExtendedProperty Settings: edvQuoteView-ShortChar01
edvQuoteView.dataView.Table.Columns["ShortChar01"].ExtendedProperties["ReadOnly"] = true;
edvQuoteView.dataView.Table.Columns["ShortChar01"].ExtendedProperties["Like"] = "ttQuoteDtlPA.ShortChar01";
// End Wizard Added ExtendedProperty Settings: edvQuoteView-ShortChar01
// End Wizard Added Conditional Block
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Jose Gomez
Sent: Tuesday, March 26, 2013 11:05 AM
To: Vantage
Subject: Re: [Vantage] E9: ABL to display Contact Name from Quote on Part Advisor
Miguel do it in this Method
PartAdvisor.GetQuoteDtlPARows. and see if the tables tehre have what you
need. Since PartAdvisor is read only uou should be ale to set the values
with no problem.
*Jose C Gomez*
*Software Engineer*
*T: 904.469.1524 mobile
E: jose@...
http://www.josecgomez.com
<http://www.usdoingstuff.com>
To: Vantage
with no problem.
*Jose C Gomez*
*Software Engineer*
E: jose@...
On Mon, Mar 25, 2013 at 5:51 PM, Miguel Santillan <msantillan@...>wrote:
> I was trying to display the Contact Name from a Quote when you hit
> RETRIEVE on the Quote it? Tab on part advisor.
> I see some sample code in ABL ( already have the Part Advisor set up using
> the wizard) but I cannot understand how I can edit the BPM for my instance.
> When I hit retrieve on Part Advisor, the following BO trigger.
> PartAdvisor.GetByID
> PartAdvisor.GetPartBinRows
> On the sample ABL that I am looking at there is a BPM Post Process on
> CashDtl.GetByID, so I am doing the same Post Process on PA.GetByID.
> The Part Advisor Quoted It? Grid is using an EPIBinding of QuoteView.
> There is no table for that. For me to get the Contact Name (QuoteCnt.Name)
> the QuoteNum is required.
> So somehow, QuoteView.ShortChar01 = QuoteCnt.Name.
> for each ttQuoteDtlPA exclusive-lock :
> find first QuoteCnt where QuoteCnt.Company = ttQuoteDtlPA.Company
> and QuoteCnt.QuoteNum = ttQuoteDtlPA.QuoteNum
> no-lock no-error.
> ttQuoteDtlPA.ShortChar01 = if avail( QuoteCnt) then QuoteCnt.Name else
> ttQuoteDtlPA.ShortChar01.
> end.
> Hopefully someone can point me in the right direction.
