E9: Easiest way to get record count
And by the way, this is an old version and I've had issues with newer versions. So I advise to install this version and not apply/upgrade to any others. Some other folks that have used this told me once they upgraded, it wasn't compatible any longer. But this version works for sure.
Sent: Thursday, January 29, 2015 5:10 PM
Subject: RE: [Vantage] E9: Easiest way to get record count
Yeah, Joe, that's me.  I'm the Squirrel guy.  :-)
Here you go:
1.  Download from here:  http://sourceforge.net/projects/squirrel-sql/files/1-stable/3.2.1/squirrel-sql-3.2.1-install.jar/download
2.  Execute installation with all default options is OK.
3.  Locate Squirrel Installation folder (C:\Program Files) and open the subfolder “Lib”
4.  Open the \\<server>\epicor\oe101b\java folder and copy all “.jar” files into the “Lib” folder above.  Do not overwrite any duplicate files.
     - Replace <server> above with your Vantage server’s name.
5.  Open Squirrel
6.  Click on “Drivers” and then the “+” button to Add a new driver.
      - Name = “OpenEdge”
      - Example URL = “jdbc:datadirect:openedge://<server>:10001;DatabaseName=mfgsys” (Replace <server> with your Vantage server; do NOT change the port here)
      - Website URL = leave blank
      - Class Name:  “com.ddtek.jdbc.openedge.OpenEdgeDriver”
7.  Click OK to Save the Driver info
8.  Add an Alias:  Click on the Alias tab in the left column and Click on the “+” button to Add a new Alias
      - Name = give it a name... ie, “Vantage TEST” or “Vantage LIVE”
      - Driver = Choose “OpenEdge” (should have a blue checkmark)
      - URL = Should be a copy of the “Example URL” in Step 6; verify.  Still leave the Port alone.
      - User Name and Password should both equal “sysprogress”
      - Click the “Auto Login” checkbox
      - Click on “Properties” button
      - On the Schemas tab, for best performance, select “Load all and cache all schemas”
      - Click on Driver Properties tab and check the “Use Driver Properties” box
      - Click the “Specify” checkbox for each of the following and fill in the appropriate value:
          - ServerName = your Vantage Server
          - User = sysprogress
          - password = sysprogress
          - PortNumber = your ODBC port (8350 for Live, 8370 for Test, 8380 for Pilot)
Sent: Thursday, January 29, 2015 3:58 PM
Thanks All.
I’m going to give Squirrel a try.
Is getting connect to Progress pretty straight forward?
I vaguely remember someone posting setup instructions.
Joe Rojas | Director of Information Technology | Mats Inc
dir: 781-573-0291 | cell: 781-408-9278 | fax: 781-232-5191
addr: 179 Campanelli Pkwy | Stoughton | MA | 02072-3734
jrojas@... | www.matsinc.com
Ask us about our clean, green and beautiful matting and flooring
[cid:3e3d28.png@0f5093d7.4db1e872]
This message is intended only for the individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail. Please notify the sender immediately by e-mail if you have received this e-mail by mistake. Please note that any views or opinions presented in this email are solely those of the author and do not necessarily represent those of the company.
Sent: Thursday, January 29, 2015 2:41 PM
Once again, this is so easily done in SQL. (quiet, Jose!) :-)
Actually, call Epicor….. they have a utility that they've given me in the past that counts all the records in all of your tables.
Or… downloand and install SQuirreL and you can do a SELECT COUNT(*) FROM PUB.ORDERHED very easily just like in SQL.
Sent: Thursday, January 29, 2015 2:00 PM
Subject: [Vantage] E9: Easiest way to get record count
Hello,
We had an issue with our Progress database and with Epicor’s help we seem to have gotten past it.
I am trying to delay doing a full initialization of the replication server because it takes several hours but I want to check to see if there is any major discrepancy in row counts for a few tables between the Progress and the replication DB.
I tried creating a BAQ with just OrderHed (for example), flagged it as summary and added a calculated field of “COUNT(OrderHed.Company)” but this just returns a blank field where I would expect to see a row count.
Any ideas on how to do this with a BAQ or is there a better way to get a row count?
jrojas@...<mailto:jrojas@...> | www.matsinc.com<http://www.matsinc.com>
[cid:bef233.png@4cfc2944.43869058]
Hello,
<!-- #ygrps-yiv-1284492989 _filtered #ygrps-yiv-1284492989 {font-family:Calibri; panose-1:2 15 5 2 2 2 4 3 2 4;} _filtered #ygrps-yiv-1284492989 {font-family:Verdana; panose-1:2 11 6 4 3 5 4 4 2 4;} _filtered #ygrps-yiv-1284492989 {font-family:Consolas; panose-1:2 11 6 9 2 2 4 3 2 4;} #ygrps-yiv-1284492989 #ygrps-yiv-1284492989 p.ygrps-yiv-1284492989MsoNormal, #ygrps-yiv-1284492989 li.ygrps-yiv-1284492989MsoNormal, #ygrps-yiv-1284492989 div.ygrps-yiv-1284492989MsoNormal {margin:0in; margin-bottom:.0001pt; font-size:12.0pt; font-family:"Times New Roman", "serif";} #ygrps-yiv-1284492989 a:link, #ygrps-yiv-1284492989 span.ygrps-yiv-1284492989MsoHyperlink { color:blue; text-decoration:underline;} #ygrps-yiv-1284492989 a:visited, #ygrps-yiv-1284492989 span.ygrps-yiv-1284492989MsoHyperlinkFollowed { color:purple; text-decoration:underline;} #ygrps-yiv-1284492989 p {
margin-right:0in;
margin-left:0in;
font-size:12.0pt;
font-family:“Times New Roman”, “serif”;}
#ygrps-yiv-1284492989 code
font-family:“Courier New”;}
#ygrps-yiv-1284492989 pre
margin:0in;
font-size:10.0pt;
#ygrps-yiv-1284492989 tt
#ygrps-yiv-1284492989 span.ygrps-yiv-1284492989HTMLPreformattedChar
font-family:Consolas;}
#ygrps-yiv-1284492989 p.ygrps-yiv-1284492989attach, #ygrps-yiv-1284492989 li.ygrps-yiv-1284492989attach, #ygrps-yiv-1284492989 div.ygrps-yiv-1284492989attach
margin-right:0in;
margin-left:0in;
font-size:9.0pt;
font-family:“Arial”, “sans-serif”;}
#ygrps-yiv-1284492989 p.ygrps-yiv-1284492989bold, #ygrps-yiv-1284492989 li.ygrps-yiv-1284492989bold, #ygrps-yiv-1284492989 div.ygrps-yiv-1284492989bold
margin-right:0in;
margin-left:0in;
font-size:10.0pt;
font-weight:bold;}
#ygrps-yiv-1284492989 p.ygrps-yiv-1284492989green, #ygrps-yiv-1284492989 li.ygrps-yiv-1284492989green, #ygrps-yiv-1284492989 div.ygrps-yiv-1284492989green
margin-right:0in;
margin-left:0in;
font-size:12.0pt;
color:#628C2A;}
#ygrps-yiv-1284492989 p.ygrps-yiv-1284492989replbq, #ygrps-yiv-1284492989 li.ygrps-yiv-1284492989replbq, #ygrps-yiv-1284492989 div.ygrps-yiv-1284492989replbq
margin:3.0pt;
font-size:12.0pt;
#ygrps-yiv-1284492989 p.ygrps-yiv-1284492989ad, #ygrps-yiv-1284492989 li.ygrps-yiv-1284492989ad, #ygrps-yiv-1284492989 div.ygrps-yiv-1284492989ad
margin-right:0in;
margin-left:0in;
font-size:12.0pt;
#ygrps-yiv-1284492989 p.ygrps-yiv-1284492989underline, #ygrps-yiv-1284492989 li.ygrps-yiv-1284492989underline, #ygrps-yiv-1284492989 div.ygrps-yiv-1284492989underline
margin-right:0in;
margin-left:0in;
font-size:12.0pt;
#ygrps-yiv-1284492989 p.ygrps-yiv-1284492989ad1, #ygrps-yiv-1284492989 li.ygrps-yiv-1284492989ad1, #ygrps-yiv-1284492989 div.ygrps-yiv-1284492989ad1
margin-right:0in;
margin-left:0in;
font-size:12.0pt;
#ygrps-yiv-1284492989 p.ygrps-yiv-1284492989ad2, #ygrps-yiv-1284492989 li.ygrps-yiv-1284492989ad2, #ygrps-yiv-1284492989 div.ygrps-yiv-1284492989ad2
margin-right:0in;
margin-bottom:7.5pt;
margin-left:0in;
font-size:12.0pt;
#ygrps-yiv-1284492989 p.ygrps-yiv-1284492989underline1, #ygrps-yiv-1284492989 li.ygrps-yiv-1284492989underline1, #ygrps-yiv-1284492989 div.ygrps-yiv-1284492989underline1
margin-right:0in;
margin-left:0in;
font-size:12.0pt;
#ygrps-yiv-1284492989 span.ygrps-yiv-1284492989cat
#ygrps-yiv-1284492989 span.ygrps-yiv-1284492989ct
#ygrps-yiv-1284492989 span.ygrps-yiv-1284492989yshortcuts
#ygrps-yiv-1284492989 span.ygrps-yiv-1284492989yshortcuts1
font-family:“Verdana”, “sans-serif”;
font-weight:bold;}
#ygrps-yiv-1284492989 span.ygrps-yiv-1284492989yshortcuts2
font-weight:normal;}
#ygrps-yiv-1284492989 span.ygrps-yiv-1284492989EmailStyle36
font-family:“Calibri”, “sans-serif”;
color:#1F497D;}
#ygrps-yiv-1284492989 .ygrps-yiv-1284492989MsoChpDefault
font-size:10.0pt;}
margin:1.0in 1.0in 1.0in 1.0in;}
#ygrps-yiv-1284492989 div.ygrps-yiv-1284492989WordSection1
I would say to start with the “company” table and link to the order table on company and then do as you said below by summarizing and counting the # orders.
One caveat we have found you can’t use a summary table on a cross-company BAQ in Epicor 9.05.702A so if you have multiple companies you will need to do it separately for each company.
Hello,
I’ve done  a calculated field in my BAQ that just equals 1, then used the summary function as a count before.
Sarah Cooley
Database Analyst
Lube-Power, Inc.
PH:  586-247-6500 Ext. 258
scooley@...
Hello,
You could run this below on your database.  It is done at the end of the Progress Dump and Load..  It will list all of your record counts..   I do think the DB has to be offline to run it though..
_proutil mfgsys -C tabanalys > Scatter.txt
After it is done, it will spit out a txt file that will give a bit of information. that first column after the table name is the record count.
                                       -Record Size (B)- ---Fragments--- Scatter
Table                Records    Size   Min   Max  Mean      Count Factor  Factor
PUB.MfgCubeDim            44    4.4K    97   112   102         44    1.0     7.1
PUB.MiscChrg              17    3.1K   176   193   184         17    1.0     6.4
PUB.MktgAct                7    1.2K   168   185   174          7    1.0     7.8
PUB.MktgAdv                0    0.0B     0     0     0          0    0.0     0.0
PUB.MktgCamp              95   18.3K   182   208   197         95    1.0     7.4
PUB.MktgEvnt             153   30.8K   189   222   206        153    1.0     7.2
PUB.MktgList               0    0.0B     0     0     0          0    0.0     0.0
PUB.MktgLstDtl             0    0.0B     0     0     0          0    0.0     0.0
PUB.MktgPub                1  180.0B   180   180   180          1    1.0     1.0
PUB.MMSyst                 1   68.0B    68    68    68          1    1.0     1.0
PUB.MobileProfile          0    0.0B     0     0     0          0    0.0     0.0
PUB.MrpProc               11    1.6K   134   181   146         11    1.0     1.0
PUB.MrpProcQueue          42    6.4K   139   199   156         42    1.0     7.1
PUB.MrpQueue              45    7.7K   146   233   174         45    1.0     7.1
PUB.MscShpDt               2  444.0B   221   223   222          2    1.0     1.0
PUB.MscShpHd             646  309.3K   408   597   490        646    1.0     6.3
--Matt Caldwell
Some Epicor/progress users are surprised, but if you have set up an OpenEdge editor, just use SQL.
SELECT COUNT(*) FROM ORDERHED
-chad
On Thu, Jan 29, 2015 at 1:48 PM, matt@... [vantage] <vantage@yahoogroups.com> wrote:
<div>
  <p></p><p>You could run this below on your database.&nbsp; It is done at the end of the Progress Dump and Load..&nbsp; It will list all of your record counts..&nbsp;&nbsp; I do think the DB has to be offline to run it though..</p><p><br></p><p>_proutil mfgsys -C tabanalys &gt; Scatter.txt</p><p><br></p><p><br></p><p>After it is done, it will spit out a txt file that will give a bit of information. that first column after the table name is the record count.</p><p><br></p><p>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; -Record Size (B)- ---Fragments--- Scatter<br>Table&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; Records&nbsp;&nbsp;&nbsp; Size&nbsp;&nbsp; Min&nbsp;&nbsp; Max&nbsp; Mean&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; Count Factor&nbsp; Factor</p><p>PUB.MfgCubeDim&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 44&nbsp;&nbsp;&nbsp; 4.4K&nbsp;&nbsp;&nbsp; 97&nbsp;&nbsp; 112&nbsp;&nbsp; 102&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 44&nbsp;&nbsp;&nbsp; 1.0&nbsp;&nbsp;&nbsp;&nbsp; 7.1<br>PUB.MiscChrg&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 17&nbsp;&nbsp;&nbsp; 3.1K&nbsp;&nbsp; 176&nbsp;&nbsp; 193&nbsp;&nbsp; 184&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 17&nbsp;&nbsp;&nbsp; 1.0&nbsp;&nbsp;&nbsp;&nbsp; 6.4<br>PUB.MktgAct&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 7&nbsp;&nbsp;&nbsp; 1.2K&nbsp;&nbsp; 168&nbsp;&nbsp; 185&nbsp;&nbsp; 174&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 7&nbsp;&nbsp;&nbsp; 1.0&nbsp;&nbsp;&nbsp;&nbsp; 7.8<br>PUB.MktgAdv&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 0&nbsp;&nbsp;&nbsp; 0.0B&nbsp;&nbsp;&nbsp;&nbsp; 0&nbsp;&nbsp;&nbsp;&nbsp; 0&nbsp;&nbsp;&nbsp;&nbsp; 0&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 0&nbsp;&nbsp;&nbsp; 0.0&nbsp;&nbsp;&nbsp;&nbsp; 0.0<br>PUB.MktgCamp&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 95&nbsp;&nbsp; 18.3K&nbsp;&nbsp; 182&nbsp;&nbsp; 208&nbsp;&nbsp; 197&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 95&nbsp;&nbsp;&nbsp; 1.0&nbsp;&nbsp;&nbsp;&nbsp; 7.4<br>PUB.MktgEvnt&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 153&nbsp;&nbsp; 30.8K&nbsp;&nbsp; 189&nbsp;&nbsp; 222&nbsp;&nbsp; 206&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 153&nbsp;&nbsp;&nbsp; 1.0&nbsp;&nbsp;&nbsp;&nbsp; 7.2<br>PUB.MktgList&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 0&nbsp;&nbsp;&nbsp; 0.0B&nbsp;&nbsp;&nbsp;&nbsp; 0&nbsp;&nbsp;&nbsp;&nbsp; 0&nbsp;&nbsp;&nbsp;&nbsp; 0&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 0&nbsp;&nbsp;&nbsp; 0.0&nbsp;&nbsp;&nbsp;&nbsp; 0.0<br>PUB.MktgLstDtl&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 0&nbsp;&nbsp;&nbsp; 0.0B&nbsp;&nbsp;&nbsp;&nbsp; 0&nbsp;&nbsp;&nbsp;&nbsp; 0&nbsp;&nbsp;&nbsp;&nbsp; 0&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 0&nbsp;&nbsp;&nbsp; 0.0&nbsp;&nbsp;&nbsp;&nbsp; 0.0<br>PUB.MktgPub&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 1&nbsp; 180.0B&nbsp;&nbsp; 180&nbsp;&nbsp; 180&nbsp;&nbsp; 180&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 1&nbsp;&nbsp;&nbsp; 1.0&nbsp;&nbsp;&nbsp;&nbsp; 1.0<br>PUB.MMSyst&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 1&nbsp;&nbsp; 68.0B&nbsp;&nbsp;&nbsp; 68&nbsp;&nbsp;&nbsp; 68&nbsp;&nbsp;&nbsp; 68&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 1&nbsp;&nbsp;&nbsp; 1.0&nbsp;&nbsp;&nbsp;&nbsp; 1.0<br>PUB.MobileProfile&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 0&nbsp;&nbsp;&nbsp; 0.0B&nbsp;&nbsp;&nbsp;&nbsp; 0&nbsp;&nbsp;&nbsp;&nbsp; 0&nbsp;&nbsp;&nbsp;&nbsp; 0&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 0&nbsp;&nbsp;&nbsp; 0.0&nbsp;&nbsp;&nbsp;&nbsp; 0.0<br>PUB.MrpProc&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 11&nbsp;&nbsp;&nbsp; 1.6K&nbsp;&nbsp; 134&nbsp;&nbsp; 181&nbsp;&nbsp; 146&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 11&nbsp;&nbsp;&nbsp; 1.0&nbsp;&nbsp;&nbsp;&nbsp; 1.0<br>PUB.MrpProcQueue&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 42&nbsp;&nbsp;&nbsp; 6.4K&nbsp;&nbsp; 139&nbsp;&nbsp; 199&nbsp;&nbsp; 156&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 42&nbsp;&nbsp;&nbsp; 1.0&nbsp;&nbsp;&nbsp;&nbsp; 7.1<br>PUB.MrpQueue&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 45&nbsp;&nbsp;&nbsp; 7.7K&nbsp;&nbsp; 146&nbsp;&nbsp; 233&nbsp;&nbsp; 174&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 45&nbsp;&nbsp;&nbsp; 1.0&nbsp;&nbsp;&nbsp;&nbsp; 7.1<br>PUB.MscShpDt&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 2&nbsp; 444.0B&nbsp;&nbsp; 221&nbsp;&nbsp; 223&nbsp;&nbsp; 222&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 2&nbsp;&nbsp;&nbsp; 1.0&nbsp;&nbsp;&nbsp;&nbsp; 1.0<br>PUB.MscShpHd&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 646&nbsp; 309.3K&nbsp;&nbsp; 408&nbsp;&nbsp; 597&nbsp;&nbsp; 490&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 646&nbsp;&nbsp;&nbsp; 1.0&nbsp;&nbsp;&nbsp;&nbsp; 6.3</p><p><br></p><p><br></p><p>--Matt Caldwell<br></p><p></p>
</div>
<div style="color:#fff;min-height:0;"></div>
Thanks All.
Hello,
Here you go:
5.  Open Squirrel
      - Name = “OpenEdge”
Thanks All.
Hello,
