We’ve recently started using Enterprise Search. I’m trying to work around two issues and am looking for any ideas. Thanks
1. Added a query to display Misc Shipment records. Records are returned by ES just fine unless I include the Ship Date field. It then throws “Unable to cast object of System.DateTime to type System.String”. I tried adding a calculated field to check for nulls and either display the date as a string or a blank string for nulls. No help.
2. We store Order Numbers in FSContHd.Number03. It’s a long story as to why. Since Number03 displayed as a decimal and didn’t have the context menu ability to open the order window, I set it as a “Like” OrderHed.OrderNum. It didn’t work and throws an error (“Unable to cast object of System.Decimal to type System.String”) when trying to look at a FSContHd result within the search. Even after updating the BAQ, deleting the index and re-creating, the Number03 column is immediately getting set as a Like OrderNum field within the ES search index properties for that query. Anyone know how I can clear this like value?
