oTrans_adapter = (ARInvoiceAdapter)csm.TransAdaptersHT["oTrans_adapter"];
I will try removing the DoEvents. It does take a bit to delete one invoice so there is definitely time for the status to get updated. It’s just not happening.
I did a simply loop for the 2 second sleep as the only action and I could see the status change. Weird.
Joe Rojas | Director of Information Technology | Mats Inc
dir: 781-573-0291 | cell: 781-408-9278 | fax: 781-232-5191
addr: 37 Shuman Ave | Stoughton | Ma | 02072-3734
jrojas@... | www.matsinc.com
Ask us about our clean, green and beautiful matting and flooring
[cid:f99d49.png@ca2dc938.4b9e56a2]
This message is intended only for the individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail. Please notify the sender immediately by e-mail if you have received this e-mail by mistake. Please note that any views or opinions presented in this email are solely those of the author and do not necessarily represent those of the company.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Jose Gomez
Sent: Thursday, January 23, 2014 3:39 PM
To: Vantage
Subject: Re: [Vantage] E9: Update text on UI status bar
Also is your oTrans_Adapter the current adapter? if so when you call GetByID and all those other methods the oTrans.PushStatusText of those methods will be pushed to the status bar so it may be flashing by rather quickly.
Jose C Gomez
Software Engineer
T: 904.469.1524 mobile
E: jose@...<mailto:jose@...>
http://www.josecgomez.com
[Image removed by sender.]<http://www.linkedin.com/in/josecgomez> [Image removed by sender.] <http://www.facebook.com/josegomez> [Image removed by sender.] <http://www.google.com/profiles/jose.gomez> [Image removed by sender.] <http://www.twitter.com/joc85> [Image removed by sender.] <http://www.josecgomez.com/professional-resume/> [Image removed by sender.] <http://www.josecgomez.com/feed/>
On Thu, Jan 23, 2014 at 3:38 PM, Jose Gomez <jose@...<mailto:jose@...>> wrote:
Have you tried removing the Application.DoEvents. ... that may conflict with the oTrans.PushStatusText...
Jose C Gomez
Software Engineer
T: 904.469.1524<tel:904.469.1524> mobile
On Thu, Jan 23, 2014 at 2:46 PM, Joe Rojas <jrojas@...<mailto:jrojas@...>> wrote:
Bump :)
dir: 781-573-0291<tel:781-573-0291> | cell: 781-408-9278<tel:781-408-9278> | fax: 781-232-5191<tel:781-232-5191>
jrojas@...<mailto:jrojas@...> | www.matsinc.com<http://www.matsinc.com>
[cid:e3d37b.png@cd793c5a.4cac22eb]
From: vantage@yahoogroups.com<mailto:vantage@yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage@yahoogroups.com>] On Behalf Of Joe Rojas
Sent: Wednesday, January 22, 2014 4:40 PM
To: vantage@yahoogroups.com<mailto:vantage@yahoogroups.com>
Subject: RE: [Vantage] E9: Update text on UI status bar
This customization is on AR Invoice Entry.
I have other code that creates a new menu item that is designed to delete all invoices in an AR Invoice Group so that the user does not have to manually delete one at a time.
When they click this new menu items, it calls the following method:
private static void deleteAllInvoicesInGroup(Object sender, ToolClickEventArgs e)
decimal grpInvTot;
int i = edvInvcHeadList.dataView.Count - 1; //zero based index
int k = 1;
DialogResult userAnswer;
userAnswer = MessageBox.Show("This will delete all invoices in this group.\nDo you want to continue?", "Confirmation", MessageBoxButtons.YesNo, MessageBoxIcon.Question);
if (userAnswer == DialogResult.Yes)
Cursor.Current = Cursors.WaitCursor;
for (int j = i; j >= 0; j--)
oTrans.PushStatusText("Deleting Invoices..." + k.ToString() + " of " + (i+1).ToString(), false);
Application.DoEvents();
oTrans_adapter.clearData();
oTrans_adapter.GetByID(Convert.ToInt32(edvInvcHeadList.dataView.Table.Rows[j]["InvoiceNum"]));
DataRow dr = edvInvcHead.dataView.Table.Rows[0];
oTrans_adapter.DeleteMaster(dr, edvInvcGrp.dataView.Table.Rows[0]["GroupID"].ToString(), edvInvcHeadList.dataView.Table.Rows[j]["InvoiceNum"].ToString(), out grpInvTot);
k = k + 1;
Cursor.Current = Cursors.Default;
oTrans.Refresh();
[cid:899eb1.png@08f7cbb9.4b9b2695]
From: vantage@yahoogroups.com<mailto:vantage@yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage@yahoogroups.com>] On Behalf Of Jose Gomez
Sent: Wednesday, January 22, 2014 3:21 PM
To: Vantage
that should / does work... what does your code look like?
Jose C Gomez
Software Engineer
E: jose@...<mailto:jose@...><mailto:jose@...<mailto:jose@...>>
On Wed, Jan 22, 2014 at 3:19 PM, Joe Rojas <jrojas@...<mailto:jrojas@...><mailto:jrojas@...<mailto:jrojas@...>>> wrote:
Hi All,
Just giving this a bump.
I tried using the code that Jose gave me but for some reason, I am not using the status bar get updated.
dir: 781-573-0291<tel:781-573-0291><tel:781-573-0291<tel:781-573-0291>> | cell: 781-408-9278<tel:781-408-9278><tel:781-408-9278<tel:781-408-9278>> | fax: 781-232-5191<tel:781-232-5191><tel:781-232-5191<tel:781-232-5191>>
jrojas@...<mailto:jrojas@...><mailto:jrojas@...<mailto:jrojas@...>> | www.matsinc.com<http://www.matsinc.com><http://www.matsinc.com>
[cid:fe6f47.png@aae2e3d3.49a6126c]
From: vantage@yahoogroups.com<mailto:vantage@yahoogroups.com><mailto:vantage@yahoogroups.com<mailto:vantage@yahoogroups.com>> [mailto:vantage@yahoogroups.com<mailto:vantage@yahoogroups.com><mailto:vantage@yahoogroups.com<mailto:vantage@yahoogroups.com>>] On Behalf Of Joe Rojas
Sent: Wednesday, January 15, 2014 2:06 PM
To: vantage@yahoogroups.com<mailto:vantage@yahoogroups.com><mailto:vantage@yahoogroups.com<mailto:vantage@yahoogroups.com>>
Thanks Jose.
I gave this a try but I’m not seeing the status bar text change. It just stays as “Readyâ€.
Here is my code in case anything jumps out at you. The code does works with the exception of updating the status bar text.
I also tried adding “Application.DoEvents()†with not luck.
oTrans.PushStatusText("Deleting Invoices..." + k.ToString() + " of " + (i+1).ToString(), true);
k = k+1;
[cid:030846.png@7b4d5686.42874203]
From: vantage@yahoogroups.com<mailto:vantage@yahoogroups.com><mailto:vantage@yahoogroups.com<mailto:vantage@yahoogroups.com>> [mailto:vantage@yahoogroups.com<mailto:vantage@yahoogroups.com><mailto:vantage@yahoogroups.com<mailto:vantage@yahoogroups.com>>] On Behalf Of Jose Gomez
Sent: Wednesday, January 15, 2014 12:24 PM
To: Vantage
oTrans.PushStatusText("Your message", true/ false) 'true false depends on whether you want the hour glass or not
Jose C Gomez
Software Engineer
T: 904.469.1524<tel:904.469.1524><tel:904.469.1524<tel:904.469.1524>> mobile
E: jose@...<mailto:jose@...><mailto:jose@...<mailto:jose@...>><mailto:jose@...<mailto:jose@...><mailto:jose@...<mailto:jose@...>>>
On Wed, Jan 15, 2014 at 12:22 PM, Joe Rojas <jrojas@...<mailto:jrojas@...><mailto:jrojas@...<mailto:jrojas@...>><mailto:jrojas@...<mailto:jrojas@...><mailto:jrojas@...<mailto:jrojas@...>>>> wrote:
Hello,
I have a customization that will be processing a known number of records.
Because the process can take a bit, depending on the number of records, I’d like to update the status bar with the progress.
Could someone share a code example of how to update the status bar?
dir: 781-573-0291<tel:781-573-0291><tel:781-573-0291<tel:781-573-0291>><tel:781-573-0291<tel:781-573-0291>> | cell: 781-408-9278<tel:781-408-9278><tel:781-408-9278<tel:781-408-9278>> | fax: 781-232-5191<tel:781-232-5191><tel:781-232-5191>
jrojas@...<mailto:jrojas@...><mailto:jrojas@...<mailto:jrojas@...>><mailto:jrojas@...<mailto:jrojas@...><mailto:jrojas@...<mailto:jrojas@...>>> | www.matsinc.com<http://www.matsinc.com><http://www.matsinc.com><http://www.matsinc.com>
[cid:252b75.png@d892c821.4ba7acde]
