We are in the process of quoting ECM also in process of quoting moving our servers to the Azure cloud.
Question about ECM, does it work well in the azure cloud?
Hi Craig,
We used ECM (DocStar at the time) but at the time, Epicor ran it in AWS in SaaS mode. It ran fine, but forget about adding JavaScript because you’ll never have access to the server and be able to control CORS.
It should run fine in Azure and you’ll have more control of the server if not running in SaaS mode. I think we couldn’t run Document Attachments using a Service, it was always client based to work. That may or may not still be true.
