EcoMlt? Blank Title 107866
FYI, I put these schemas up a while back for a similar question. http://tech.groups.yahoo.com/group/vantage/files/Schemas/
There is one in there for the ECO table set.
Sent: Thursday, February 23, 2012 5:19 PM
Subject: RE: [Vantage] EcoMlt?
Jose,
Are you querying the ecomtl table? It has revisionnum in it.. wouldn't you query by the parents revnum?
Rob Bucek
Production Control Manager
PH: (715) 284-5376 ext 311
Mobile: (715)896-0590
FAX: (715)284-4084
[Description: cid:mailto:1.234354861%40web65412.mail.ac4.yahoo.com]<http://www.dsmfg.com/>
(Click the logo to view our site)<http://www.dsmfg.com/>
From: mailto:vantage%40yahoogroups.com [mailto:mailto:vantage%40yahoogroups.com] On Behalf Of Jose Gomez
Sent: Thursday, February 23, 2012 12:34 PM
To: Vantage
Subject: [Vantage] EcoMlt?
Hi All
If I have an EcoMtl record and it has PullAsAsmb =true
I'd like to run a query and get that assembly's EcoMtl records... AKA going
all the way down the levels, the problem that I am having is that EcoMtl
does not give you the Revision of the Part so I can't query the table
without that, how do i get what revision that EcoMtl is attached ot?
Thanks!~
*Jose C Gomez*
*Software Engineer*
*checkout my new blog <http://www.usdoingstuff.com> *
*T: 904.469.1524 mobile
E: mailto:jose%40josecgomez.com<mailto:jose%40josecgomez.com>
http://www.josecgomez.com
No virus found in this message.
Checked by AVG - www.avg.com
Version: 2012.0.1913 / Virus Database: 2114/4827 - Release Date: 02/23/12
Hi All
Thanks!~
*Jose C Gomez*
*Software Engineer*
E: jose@...
I needed the same thing but in SQL so I wrote a stored function. You give the function a Partnum and gives back the active Rev. I'm not a SQL guru or anything but it works for me.
CREATE FUNCTION [dbo].[AGM_ActiveRev]
-- Add the parameters for the function here
@PartNum nvarchar(50)
RETURNS @Revision TABLE
[Revision] nvarchar(10)
AS
BEGIN
INSERT INTO @Revision
SELECT top 1
(CASE
WHEN (select sum(pr.approved) from PartRev as PR where PR.PartNum = @PartNum) = 0
THEN
(select top 1 RevisionNum
from PartRev as PR
where PR.PartNum = @PartNum and
PR.EffectiveDate < getdate()
order by effectivedate desc)
ELSE
from PartRev as PR
where PR.PartNum =@PartNum and
PR.approved = 1 and
END)
FROM PartRev
where partrev.PartNum = @PartNum
RETURN
END
GO
Tom Christie
Manufacturing Engineer
AGM Container Controls
3526 E Ft. Lowell Road
Tucson AZ, 85716
PH: 520-881-2130
FX: 520-881-4983
www.AGMcontainer.com<http://www.agmcontainer.com/>
AS
BEGIN
SELECT top 1
(CASE
THEN
from PartRev as PR
ELSE
from PartRev as PR
PR.approved = 1 and
END)
FROM PartRev
RETURN
END
GO
Tom Christie
Tucson AZ, 85716
PH: 520-881-2130
FX: 520-881-4983
Thanks Tom
*Jose C Gomez*
*Software Engineer*
E: jose@...
On Thu, Feb 23, 2012 at 5:08 PM, Tom J. Christie <tchristie@...
> AS
> BEGIN
> SELECT top 1
> (CASE
> @PartNum) = 0
> THEN
> from PartRev as PR
> ELSE
> from PartRev as PR
> PR.approved = 1 and
> END)
> FROM PartRev
> RETURN
> END
> GO
> Tom Christie
> Tucson AZ, 85716
> PH: 520-881-2130
> FX: 520-881-4983
There's a GetDataSetForTree method on the BOMSearch BO that has a flag to blow-through the whole BOM. Maybe there's an equivalent in the EngWorkBench adapter.
Mark W.
Jose,
Rob Bucek
FAX: (715)284-4084
[Description: cid:1.234354861@...]<http://www.dsmfg.com/>
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Jose Gomez
To: Vantage
Hi All
Thanks!~
*Jose C Gomez*
*Software Engineer*
E: jose@...<mailto:jose%40josecgomez.com>
In drilling down into an indented BOM, I have always used ECORev and ECOMtl back and forth to get the most recent revision number of the material parts. Hope that helps.
Aimee
--- In vantage@yahoogroups.com, Rob Bucek <rbucek@...> wrote:
> Jose,
> Rob Bucek
> FAX: (715)284-4084
> To: Vantage
> Hi All
> Thanks!~
> *Jose C Gomez*
> *Software Engineer*
