Hi Guys,
I am battling with a sync error on my EDA sync with E10 (10.2.300). One item is failing with the below error message:
INFO 2019-11-28 11:50:15 Syncing ‘i_#Epicor_apinvdtl_measures’.
INFO 2019-11-28 11:50:15 Starting sync session for item ‘i_#Epicor_apinvdtl_measures’.
ERROR 2019-11-28 11:50:20 Client side error.
Sync failed for item ‘i_#Epicor_apinvdtl_measures’.
Exception: String or binary data would be truncated.
The statement has been terminated.
Stack Trace:
at System.Data.SqlClient.SqlConnection.OnError(SqlException exception, Boolean breakConnection, Action1 wrapCloseInAction)
at System.Data.SqlClient.TdsParser.ThrowExceptionAndWarning(TdsParserStateObject stateObj, Boolean callerHasConnectionLock, Boolean asyncClose)
at System.Data.SqlClient.TdsParser.TryRun(RunBehavior runBehavior, SqlCommand cmdHandler, SqlDataReader dataStream, BulkCopySimpleResultSet bulkCopyHandler, TdsParserStateObject stateObj, Boolean& dataReady)
at System.Data.SqlClient.SqlDataReader.TryConsumeMetaData()
at System.Data.SqlClient.SqlDataReader.get_MetaData()
at System.Data.SqlClient.SqlCommand.FinishExecuteReader(SqlDataReader ds, RunBehavior runBehavior, String resetOptionsString, Boolean isInternal, Boolean forDescribeParameterEncryption, Boolean shouldCacheForAlwaysEncrypted)
at System.Data.SqlClient.SqlCommand.RunExecuteReaderTds(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, Boolean async, Int32 timeout, Task& task, Boolean asyncWrite, Boolean inRetry, SqlDataReader ds, Boolean describeParameterEncryptionRequest)
at System.Data.SqlClient.SqlCommand.RunExecuteReader(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, String method, TaskCompletionSource`1 completion, Int32 timeout, Task& task, Boolean& usedCache, Boolean asyncWrite, Boolean inRetry)
at System.Data.SqlClient.SqlCommand.RunExecuteReader(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, String method)
at System.Data.SqlClient.SqlCommand.ExecuteReader(CommandBehavior behavior, String method)
at Phocas.Sync.Client.PartGenerators.ODBCQueryDataItemPartGenerator.CreateReader(IParametersProvider parametersProvider)
at Phocas.Sync.Client.ItemSyncer.CreatePartGenerator()
at Phocas.Sync.Client.ItemSyncer.d__63.MoveNext()
I understand that some data is too big but how do I determine which field it is referring to?
