Probably a query for @bconner, but somebody else may know the answer…
New found love for EDD - started using it recently, and it’s proving to be a great tool for Directors to use to ask questions based on real data - nobody can hide from the KPIs!
Dates are behaving strangely though. This example above, the data should be ordered by the date column in the EDD config - if I do reverse date order, then the dates are correct. Doing ascending date like this, then it doesn’t get it correct for some reason.
Also, I want it in UK date format DD/MM/YYYY not US format of MM/DD - is that config, or a bug that it should follow System Culture but isn’t doing so?
Many Thanks
Mark
