Has anyone seen it vanish before? If so what did you do to get it back?
I have - you can redeploy it from the EAC. Or, in the API you can just set the URL again.
> ice.bo.shelllayoutsvc/SaveDataDiscoveryUrl
Tried both with no luck
There is a GetDataDiscoveryUrl too. Does that return the EDD endpoint?
Using the GetDataDiscoveryUrl it pulls the correct endpoint.
I can browse to the endpoint in the browser no problem. I can access Data Discovery from the tree view in the client no problem. However the icon has vanished and i cannot access from the tree view in the browser either.
I have had support look at it and they are baffled as well.
Are you on Prem? If so, did you forget to enable EDD during install? If you’re SaaS make a ticket they may have forgotten.
Hi Randy,
EDD is enabled in EAC
Daniel
Try setting it to blank and then setting it back to that current value?
Same
Support have suggested creating a new EDD DB and pointing the extension to that.
