Hello,
I have created a UD field called HourRate_c in the JCDept table.
I intend to create a UBAQ listing all records in JCDept so for when finance dept will change the rate for each dept in JCDept (they do this twice / year) , that change will affect all employees in EmpBasic having that same dept. (kind of automatize the process instead of doing this via DMT.)
I have I guess multiple ways to do this in a BPM MD (on JCDept.UpdateExt ) using custom code (can someone help me with the syntax of using the BO ? )
or
Using the widgets
Again can someone show me how to use them? I tried to use EmpBasic.GetList
but I was expecting I could set in the Specified parameters something like EmpBasic.JcDept = ttJCDeptRow.JCDept… but I did not…
Where can I find examples or if someone can direct me in the right path?
Pierre
