I am working on a customization to the Job Entry Form that does the following:
1. List Serial Numbers Assigned to that Job
2. Allow user to select Serial Numbers INDIVIDUALLY, ALL, or NONE (via a some field on the s/n table)
3. A button on the form flips a UD checkbox field on the JobHead table, which fires a BAM, which fires a custom .p program to print labels out via bartender.
My issues are in step #2:
A) I have a EpiUltraGrid that I populate using the code below. How can I populate this grid with SerialNumber data that is editable?
B) What field can I use as a flag? I see no UD fields in this table. Could I use "Selected" field - what is this field used for, it seems perfect? Or, could I use the SNReference field somehow?
Thanks in advance!
Keith Walter
Private Sub edvJobHead_EpiViewNotification(view As EpiDataView, args As EpiNotifyArgs) Handles edvJobHead.EpiViewNotification
'// ** Argument Properties and Uses **
'// view.dataView(args.Row)("[FieldName]")
'// args.Row, args.Column, args.Sender, args.NotifyType
'// NotifyType.Initialize, NotifyType.AddRow, NotifyType.DeleteRow, NotifyType.InitLastView, NotifyType.InitAndResetTreeNodes
Try
If (args.Row > -1) Then
Dim ds As DataSet
Dim opts as SearchOptions
Opts = new SearchOptions(SearchMode.AutoSearch)
opts.DataSetMode = DataSetMode.ListDataSet
opts.SelectMode = SelectMode.MultiSelect
opts.PreLoadSearchFilter = "JobNum = '" & edvJobHead.dataview(edvJobHead.Row)("JobNum").ToString() & "'"
ds = Epicor.Mfg.UI.FrameWork.ProcessCaller.LaunchSearch(oTrans, "SerialNoAdapter", opts)
ugdSerialNumbers.DataSource = ds.Tables(0)
Else
ugdSerialNumbers.DataSource = Nothing
End If
Catch ex as exception
MsgBox(ex.message)
End try
End Sub
Thanks in advance!
Keith Walter
Try
Dim ds As DataSet
Else
End If
MsgBox(ex.message)
End try
End Sub
