Education DB, cannot start AppServer (9.05.605)
Hi Ned,
I'd done that, but I had a look again due to your suggestion.
I noticed that the mfgsyssh64.bkup file in the newdb folder is newer than the one in the training folder, so I copied over the newer version and restored the schema holder and everything is now ok.
Thanks for your help, case closed :)
--- In vantage@yahoogroups.com, "Ned" <TechnoBabbly@...> wrote:
> You need to update your schema holders to the newest version.
> -----Original Message-----
> From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of
> Clive
> Sent: Tuesday, August 02, 2011 12:36 PM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Education DB, cannot start AppServer (9.05.605)
> Hi,
> I'm having trouble starting the AppServer for the Education/Training DB in
> 9.05.605
> Here's a small part of the EpicorTrain905 server log...
> [11/08/02@12:11:37.755+0100] P-010320 T-010324 1 AS -- (Procedure:
> 'as/startup.p' Line:0) ** CRC for ExtCompany does not match CRC in
> as/startup.p. Try recompiling. (1896) [11/08/02@12:11:37.755+0100] P-010264
> T-010268 1 AS -- (Procedure: 'as/startup.p' Line:0) ** CRC for ExtSysTable
> does not match CRC in as/startup.p. Try recompiling. (1896)
> ... it's the correct MS SQL DB for the level of Epicor 9, I'm stumped.
> Thanks.
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must have
> (1) To access the Files Section of our Yahoo!Group for Report Builder and
> http://groups.yahoo.com/group/vantage/linksYahoo! Groups Links
Hi,
I'm having trouble starting the AppServer for the Education/Training DB in 9.05.605
[11/08/02@12:11:37.755+0100] P-010320 T-010324 1 AS -- (Procedure: 'as/startup.p' Line:0) ** CRC for ExtCompany does not match CRC in as/startup.p. Try recompiling. (1896)
[11/08/02@12:11:37.755+0100] P-010264 T-010268 1 AS -- (Procedure: 'as/startup.p' Line:0) ** CRC for ExtSysTable does not match CRC in as/startup.p. Try recompiling. (1896)
Thanks.
Clive,
You might have more corrupt files. Just thinking since you had a similar problem the other day. You should be able to restore the training database though. With progress I have a zip file or something similar.
--- In vantage@yahoogroups.com, "Clive" <clive.1972@...> wrote:
> Hi,
> Thanks.
Clive
Hi,
9.05.605
Thanks.
