EFx - Is this a job for CallService?
Howdy,
I have a function that checks to see if I need to add a copart to a job and adds it, if so.
I’ve been using the context factory to create an erpContext.Db to get the job entry service. But now I’ve added “requires transaction” to the function header and that’s causing issues.
Is CallService a candidate here? How might it be applied?
Joe
The current code in a custom code block:
// check/add coparts
outTest = "";
var context = (Erp.ErpContext)Ice.Services.ContextFactory.CreateContext();
var erpContext = new Erp.Internal.Lib.CCredChk(context); // used this library/assembly only for erpContext
Erp.Contracts.JobEntrySvcContract jobEntry = Ice.Assemblies.ServiceRenderer.GetService<Erp.Contracts.JobEntrySvcContract>(erpContext.Db, true);
var dsJobEntry = new Erp.Tablesets.JobEntryTableset();
bool coPartExists = false;
string partNum = String.Empty;
string addPartList = String.Empty;
jobHasCoparts = false;
string jobHeadPartNum = "";
dsJobEntry = jobEntry.GetByID(jobNum);
//using(var txscope = IceDataContext.CreateDefaultTransactionScope())        //Start Transaction ----------------- added "requires transaction" at the function level
  var jobHead_xRow = (from row in dsJobEntry.JobHead
  where row.Company == Session.CompanyID &&
  row.JobNum.ToUpper() == jobNum.ToUpper()
  select row).FirstOrDefault();
  if (jobHead_xRow != null)
    foreach(var ud102A_xRow in (from row in Db.UD102A
    row.Key1 == jobNum &&
    row.Key2 == jobSeq &&
    row.Completed_c != true
    select row))
      partNum = ud102A_xRow.PartNum_c;
      jobHeadPartNum = jobHead_xRow.PartNum;
      if (jobHeadPartNum.ToUpper() != partNum.ToUpper()) // job num
        var jobPart_xRow = (from row in dsJobEntry.JobPart
        row.JobNum.ToUpper() == jobNum.ToUpper() &&
        row.PartNum.ToUpper() == partNum.ToUpper()
        if (jobPart_xRow != null)
        else
          if (!("~"+addPartList).Contains("~"+partNum + "~"))
          addPartList += partNum + "~";
  // trim the last separator from the string
  if (addPartList.Length > 0)
    if (addPartList.Substring(addPartList.Length -1 ,1) == "~")
    addPartList = addPartList.Substring(0,addPartList.Length - 1);
  bool jobUpdated = false;
  if (addPartList != String.Empty)
    string delimiterChar = "~";
    string[] stringSeparators = new string[] { delimiterChar };
    string[] partAry = addPartList.Split(stringSeparators,StringSplitOptions.None);
    foreach (string coPartNum in partAry)
      jobEntry.GetNewJobPart(ref dsJobEntry,jobNum);
      jobUpdated = false;
      row.JobNum == jobNum &&
      row.RowMod == IceRow.ROWSTATE_ADDED
        jobPart_xRow.PartNum = coPartNum;
        jobUpdated = true;
        jobEntry.ChangeJobPartPartNum(ref dsJobEntry);
      if (jobUpdated)
        jobEntry.Update(ref dsJobEntry);
  //txscope.Complete();                            //Close Transaction
  var jobPart_xRow2 = (from row in dsJobEntry.JobPart
  row.PartNum != jobHeadPartNum
  if (jobPart_xRow2 != null)
    jobHasCoparts = true;
Okay, stealing a bit o’ code from klincecum:
outTest = "";
CallService<Erp.Contracts.JobEntrySvcContract>(jobEntry =>
  Erp.Tablesets.JobEntryTableset dsJobEntry = jobEntry.GetByID(jobNum);
    select row))
        else
      jobUpdated = false;
        jobUpdated = true;
        // is already 'added' jobPart_xRow.RowMod = IceRow.ROWSTATE_UPDATED;
      if (jobUpdated)
Addendum: How would one ignore the facade when using CallService in this manner?
Joe
Did you found answer?
