EKW (handheld) users cannot change receipt quantity. Error: A Valid Our Quantity is required
Anyone ever see this with Epicor Kinetic Warehouse?
I have not seen it in person, and I am waiting on more details. But here is a screenshot (less the URLs). I’ll see what they say.
Oddly, I don’t see it in the event viewer on the server at that time (yes I converted from UTC).
They are only just starting to try to use EKW for receiving, if you wonder why we’ve never seen this before.
A related thought I had: I noticed today that the EKW interface does not seem to have a place to switch between Vendor Qty and Our Qty - it’s just “Input.” It makes me curious, given the error message.
(Pic from Biscit.)
On the screenshot, the Input field is 0, that will trigger the error. If the team doesn’t want to type the value, there is a setting to default that to the expected receipt quantity. You may also use a scan incrementor to scan each of the ten pieces.
If that’s not it, I’d be interested to know, on company configuration > shipping/receiving What is the receipt default quantity.
Oh, that’s not a real screenshot of our device - I borrowed that from your company’s docs. (But the photograph is ours of course.)
Default is Supplier Qty - we changed that about 4-6 months ago, actually.
Like I implied, it’s embarrassing, but we’ve had the Biscit licenses for many years now, but they never do PO receipts. Mostly used for order picking, I think. But since we pay for them, management rightfully wants people to use ALL of the app.
Even with that though, I have not heard any more on the issue here. Which more likely means they gave up again…
Thank you for replying, though - I had forgotten. I’ll have to pester some coworkers here.
But since I have you here… what is the idea with the receipt quantity in the app (“Our” vs. Supplier)? Are you saying that it uses the company config setting? I’d think it would use the setting on the PO in the same way that Receipt Entry (in Kinetic) does.
We’ve had trouble with PO receipts when the UOM is different between “Ours” and “Theirs”. I submitted tickets in the past but it never really gets resolved. We have just saved those off to the side and used Epicor to get those done.
@JasonMcD, I wanted to be sure with my answer, so to test I:
  • changed my company configuration to receive in supplier UOM, and my app changed to specify the supplier UOM on the handheld
  • created a part that uses EA for inventory and DZ for supplier
  • put in a PO with two lines, one specifying our quantity and one specifying supplier quantity
The behavior on the app respected the company configuration both times. I was able to receive both without any issues.
I’m assuming you’ve tested this on multiple POs. I wonder if you have any UOMs associated with either supplier or inventory UOM that have been inactivated on a part?
I haven’t seen this error before so I’m trying to think of ways to duplicate the issue in my environment.
One thing to test, in the EKW settings > Receipt there is an option to “Set Quantity to Remaining”. Toggle that on and test a receipt without changing the quantity.
@Doug.C consider emailing support@biscit.com with the issue to get a ticket directly with Biscit on this one.
@JasonMcD did you ever get this solved?
If you have any feedback on using PO Receipt in EKW, we are evaluating any opportunities for improvement on these screens and any suggestions or info on issues would be appreciated.
No, but that’s really just lack of testing on my part. And no one has complained, which means they stopped trying, not that it was resolved/understood/etc.
Do they use EKMW for receiving right now?
Pretty sure no.
Thanks Jason.
Sorry if this is just is me just repeati g something that has been said. For the same handheld scenario does it work on kinetic receipt screen? I have seen issues before on the receipt screen where the UOM are not setup correctly, though that is normally the decimals issue…
It works on the receipt screen in Epicor, you can change between ours and supplier whenever.
Wonder if they are using a different rest endpoint…
You can see what endpoints they are using in EKMW- which I wish you could hide from end users.
