We don't use tasks so I haven't looked at them too much, but I did
get one working:
* I setup 1, 2 and 3 like you said.
* In 1, what Global Alert did you use? I used "Task has been
assigned".
* You don't mention it, but I presume you then created a Task Set and
added in the Task you created as a Milestone. I set the "Current
Stage" as "Lead" for that Milestone.
* I then assigned this new Task Set to a particular Territory,
assigned that Territory to a specific Customer and created a new
Quote for that Customer. As soon as I did, I got an email.
(Do a search on you Vantage server for the other logfile. It may just
be in a different folder.)
HTH,
Nigel.
get one working:
assigned".
HTH,
Nigel.
--- In vantage@yahoogroups.com, "pbriscoe10" <pbriscoe10@...> wrote:
> Thank you Nigel for your detailed instructions as this was my first
> time using BAM. I created the alert and... it worked!
> Now that my email seems to be working, I have to figure out why my
> task alerts are not being sent. I will try and look into the
> salesperson names as mentioned earlier, but I believe everything is
> correct in that regard. Are there any other places I may be able to
> look.
> Also, the epicor-smtp.log.txt is still not being created, which is
a
> bit strange.
> I can see light at the end of the tunnel on this issue, thanks for
> all your help!
> --- In vantage@yahoogroups.com, "Nigel Kerley" <nigel.kerley@>
> wrote:
> > I would start with something simple until you get it up and
> running:
> > Create a new BAM on the Customer table, add in the CustID field
> only,
> > no rules, tick "Create Log" and "Send Alert" and add your own
> > address into "To".
> > Than create a new Customer. As soon as you save it, you should
get
> an
> > email.
> > Things to check:
> > * does your Exchange server require authorisation. AFAIK, Vantage
> > can't supply a username/password so you may have to switch this
> off.
> > * did you check that your Exchange server allows relaying from
> your
> > Vantage server?
> > * you mention the GlobalAlertsEmail.log. What about the epicor-
> > smtp.log.txt? Has this been created? It's this log that records
> > communications with your Exchange Server.
> > Nigel.
> > --- In vantage@yahoogroups.com, "pbriscoe10" <pbriscoe10@> wrote:
> > > Okay,
> > > It looks like our log file has been created! The only problem
> now
> > is
> > > that I don't seem to be receiving emails. In addition, the log
> > > doesn't seem to be producing any errors. Does the system have
to
> be
> > > restarted after changing the smtp setting in the config file?
> Below
> > > are the steps I have taken to have alerts sent to a salesperson
> > when
> > > a Task is assigned to them:
> > > 1) Activate the task alert in Global Alert Maintenance
> > > 1a. once there, I check the boxes "Active" and "Send Alert"
> > > 1b. I set the "From" email and Label
> > > 1c. I leave the TO: and CC: boxes blank assuming that
> the "Specific
> > > Recipient: Salesperson" area means that the email will be sent
> to
> > > the salesperson who the task is assigned to. (Note: I have also
> > > tried filling in the TO: field and still have not received an
> email)
> > > 2) Set the salesperson's email in Work Force Maintenance
> > > 2a. Also checked the "Send Alert:" box
> > > 3) Create a task
> > > 3a. Make sure the send alert on creation and completion boxes
> are
> > > checked
> > > I don't think I am missing anything in this process, but I am
> still
> > > not receiving any emails. If I have missed something or can try
> > > something else, I would really appreciate the input. Below is a
> > > snippet of my GlobalAlertsEmail log file. Thanks!
> > > 11/24/08 15:05:39 (xxxx-vantage:8301) Global Alerts Email
> Process -
> > > Processing
> Process -
> > > Completed
> > > 11/24/08 15:06:39 (xxxx-vantage:8301) Global Alerts Email
> Process -
> > > Processing
> Process -
> > > Completed
