Emails from Vantage
sent this to my hosted email provider. When I setup all the email accounts I added *@... to the whitelist and have it set to send spam and quarantine emails to inbox with [spam] and [quarantine] in the subject line.
--- In vantage@yahoogroups.com, Epi Cor <psworn@...> wrote:
> From experience, I know that ASSP and Spam Assassin will block the emails if they are not whitelisted. ÂÂ
> I usually just add the address of *@... to the NoProcessing list.ÂÂ
> Works like a charm.
> From: jamesd <jdaniel1127@...>
> To: vantage@yahoogroups.com
> Sent: Thursday, September 29, 2011 12:14 PM
> Subject: [Vantage] Re: Emails from Vantage
> ÂÂ
> Here is what is in the logs, I changed ip addresses to xxx.xxx.xxx.xxx and real email addresses to email address
> I assume it is working, just blcking the emails as spam???
> from globalalertsemail.txt
> 09/20/11 17:28:30 (VNTGDB:8301) -------------------- Starting --------------------
> 09/20/11 17:28:30 (VNTGDB:8301) Global Alerts Email Process - Started
> 09/20/11 17:28:30 (VNTGDB:8301) Global Alerts Email Process - Processing
> 09/20/11 17:28:30 (VNTGDB:8301) Global Alerts Email Process - Processing Email
> 09/20/11 17:28:30 (VNTGDB:8301) Global Alerts Email Process - Sending Email
> 09/20/11 17:28:45 (VNTGDB:8301) Global Alerts Email Process - Email Send Failure - SMTP Code:554 554 5.7.1 Service unavailable; Client host [xxx.xxx.xxx.xxx] blocked using sbl-xbl.spamhaus.org; http://www.spamhaus.org/query/bl?ip=xxx.xxx.xxx.xxx
> 09/20/11 17:28:45 (VNTGDB:8301) Global Alerts Email Process - Processing Email
> 09/20/11 17:28:45 (VNTGDB:8301) Global Alerts Email Process - Sending Email
> 09/20/11 17:28:51 (VNTGDB:8301) Global Alerts Email Process - Email Send Failure - SMTP Code:554 554 5.7.1 Service unavailable; Client host [xxx.xxx.xxx.xxx] blocked using sbl-xbl.spamhaus.org; http://www.spamhaus.org/query/bl?ip=xxx.xxx.xxx.xxx
> 09/20/11 17:28:51 (VNTGDB:8301) Global Alerts Email Process - Processing Email
> 09/20/11 17:28:51 (VNTGDB:8301) Global Alerts Email Process - Creating Email Attachment
> from epicor-smtp.log
> ************** ****** New Group ******* ************
> Socket Email started
> Input Parameters
> EmailFrom = email address
> EmailTo = email address
> EmailCC =
> EmailAttachments =
> EmailFiles =
> EmailSubject = PO 33101 requires your approval
> EmailBody = Please review the PO and consider approval
> EmailMIMEHeader = text/plain; charset=us-ascii
> LocalHostName = VNTGDB
> 09/29/11 11:43:03 opening socket
> 09/29/11 11:43:11 Socket Connection Established.
> 09/29/11 11:43:12 vstate 1
> cSMTPResponse 220 mail1.hyperoffice.com ESMTP Postfix
> iReponseLength41
> 09/29/11 11:43:12 cLast-Command nothing
> 09/29/11 11:43:12 SendCommand: HELO VNTGDB
> 09/29/11 11:43:12 SendCommand Finished:
> 09/29/11 11:43:13 vstate 1
> cSMTPResponse 250 mail1.hyperoffice.com
> iReponseLength27
> 09/29/11 11:43:13 cLast-Command HELO
> 09/29/11 11:43:13 SendCommand: MAIL From: <email address>
> 09/29/11 11:43:13 SendCommand Finished:
> 09/29/11 11:43:14 vstate 1
> cSMTPResponse 250 2.1.0 Ok
> iReponseLength14
> 09/29/11 11:43:14 cLast-Command MAIL
> 09/29/11 11:43:14 SendCommand: RCPT TO: <email address>
> 09/29/11 11:43:14 SendCommand Finished:
> 09/29/11 11:43:15 vstate 1
> cSMTPResponse 554 5.7.1 Service unavailable; Client host [xxx.xxx.xxx.xxx] blocked using sbl-xbl.spamhaus.org; http://www.spamhaus.org/query/bl?ip=xxx.xxx.xxx.xxx
> iReponseLength144
> 09/29/11 11:43:15 cLast-Command RCPT
> 09/29/11 11:43:15 SendCommand: QUIT
> 09/29/11 11:43:15 SendCommand Finished:
> 09/29/11 11:43:16 vstate 1
> cSMTPResponse 221 2.0.0 Bye
> iReponseLength15
> 09/29/11 11:43:16 cLast-Command QUIT
> QUIT Response
> 09/29/11 11:43:16 End SMTP Session.
> --- In vantage@yahoogroups.com, jdaniel1127@ wrote:
> > yes we do have mfgwrk803 directory, I will do a search for those log files.
> > ----- Original Message -----
> > From: "cooner_55421" <cooner_55421@>
> > Sent: Thursday, September 22, 2011 6:41:24 PM
> > ÂÂÂ
> > Maybe epicor-smtp.log.txt and GlobalAlertsEmail.log
> > Do you have an mfgwrk803 directory?
> > --- In vantage@yahoogroups.com , "jamesd" <jdaniel1127@> wrote:
> > > Changed email providers and I found vantage.manager email address in company and changed it to our new providers address and restarted the vantage mfgsys803 app process. We use this for po approvals over your signing limit. It still doesn't work and I don't know where else to look. Is there some sort of log file that would show me if SMTP is trying to send email?
Â
Input Parameters
EmailCC =
EmailAttachments =
EmailFiles =
iReponseLength41
iReponseLength27
iReponseLength14
iReponseLength144
iReponseLength15
QUIT Response
> From: "cooner_55421" <cooner_55421@...>
> ÂÂ
When you say provider - I assume you mean a 3rd party server.
My guess is that you'll need to work with them on their end.
> Input Parameters
> EmailCC =
> EmailAttachments =
> EmailFiles =
> iReponseLength41
> iReponseLength27
> iReponseLength14
> iReponseLength144
> iReponseLength15
> QUIT Response
> > ÂÂ
Works like a charm.
Â
Input Parameters
EmailCC =
EmailAttachments =
EmailFiles =
iReponseLength41
iReponseLength27
iReponseLength14
iReponseLength144
iReponseLength15
QUIT Response
> ÂÂ
