Employee Efficiencies and Splitting Burden
Also, I don't think I answered your question directly. Here is a
generic example to show how split burden is calculated;
5 employees working the same workcenter all day (8 hrs) = 40 labor
hours. The split would be equal to 40 hrs / 5 employees = 8 burden
hours.
Does this help?
Bruce Butler
IT Manager
Knappe & Koester, Inc.
_____
Of Robert MacDonald
Sent: Tuesday, November 07, 2006 1:50 PM
Subject: RE: [Vantage] Employee Efficiencies and Splitting Burden
Bruce,
We are trying to determine the best way to setup our work centers.
In this case, we have 6 workers working on the same job (sanding), with
a total of 14.86 labor hours.
We have the work center setup as you have indicated to split the burden.
One employee has 1.25 labors, and .77 earned hours. The burden in
Vantage is .29.
Calculating his efficiency .77/.29 *100 = 265%
His actual efficiency should be 80%.
How is the split burden calculated?
We are having discussions regarding changing this type of work center to
Labor=Burden as each worker is equivalent to a machine.
What do you think?
Thanks for your input.
Rob
Behalf
Of Bruce Butler
Sent: Tuesday, November 07, 2006 9:00 AM
Subject: Spam:RE: [Vantage] Employee Efficiencies and Splitting Burden
The appropriate work center set up would be to check the box for split
burden.
Assuming an 8 hr day, this would give the following result;
2 Workers 1 Job / 1 Workcenter: Labor Hours = 16 Burden Hours = 8
This is the exception for the way we operate. I would love to have the
ability to control this on a job by job basis as we use our workcenters
in different scenerios based on job. As of 6.1, this is not possible.
Bruce Butler
IT Manager
_____
Behalf
Of Robert MacDonald
Sent: Friday, November 03, 2006 3:41 PM
Subject: [Vantage] Employee Efficiencies and Splitting Burden
Hi All,
Our supervisors/managers have started to use the labor edit report, and
they have complained that the efficiencies are incorrect.
After checking into the issue I found that the efficiency is calculated
as; earned hrs/burden hrs * 100. The problem is, if more than one person
works on the same job the burden is split, with the result that an
individual's efficiency is wrong.
I called support but they we not much help.
Does anyone know of the proper work center maintenance setup that would
allow splitting the burden and getting the correct individual employee
efficiencies correct?
Rob MacDonald
Ground Effects Ltd.
Hi All,
Rob MacDonald
Ground Effects Ltd.
Shouldn't the Employee efficiency be based on the Burden hours and
not the labor hours.
I am assuming you have someone running 2 machines at the same time ?
where labor hours would be 4 hours to each machine but burden hours
would be 8 hours on each machine..
if this isn't what you are doing..e-mail me
marty1325@...
marty rogers
--- In vantage@yahoogroups.com, "Robert MacDonald" <rmacdonald@...>
wrote:
> Hi All,
and
calculated
person
would
employee
> Thanks,
> Rob MacDonald
> Ground Effects Ltd.
Resource (or machine) efficiency would be based upon the burden hours.
Employee efficiency would be based on the labor hours of the task. In
most cases you should be interested in the resource and not the
employee as that is what is doing the work.
Charlie
burden.
Bruce Butler
IT Manager
_____
Of Robert MacDonald
Hi All,
Rob MacDonald
Ground Effects Ltd.
Bruce,
Vantage is .29.
What do you think?
Rob
Of Bruce Butler
burden.
Bruce Butler
IT Manager
_____
Behalf
Of Robert MacDonald
Hi All,
Rob MacDonald
Ground Effects Ltd.
We generally look at burden as the machine + overhead, and labor as
labor. In your case it sounds like the workers are the machines. When I
recommended splitting the burden I was assuming, from your previous
entry, you had multiple workers on one "machine."
From what you say it sounds like Burden should equal labor.
Financially, your burden is going to multiply by 6 which from your
example sounds right. This should also correct the efficiency.
I have two documents we generated to keep this somewhat straight in our
heads. If interested email me, and I will send it to you.
Bruce Butler
IT Manager
_____
Of Robert MacDonald
Bruce,
Vantage is .29.
What do you think?
Rob
Behalf
Of Bruce Butler
burden.
Bruce Butler
IT Manager
_____
Behalf
Of Robert MacDonald
Hi All,
Rob MacDonald
Ground Effects Ltd.
