Hello,
Has anyone had any luck using an android emulator that works well with the EWK app. None of the ones I have used are functional. Any recommendations or work arounds would be appreciated!
Thank you.
Hello,
Thank you.
Just use your phone . . .
I just use the standard Emulator from the Android SDK works just fine.
silly ![]()
Found one thread on topic…
We don’t use one. We use a test device which uses a license to do any testing.
Understood…just linked the thread for @TravisSchaniel to read
I’ll check it out thank you John
