If you don't mind doing it by controlling the vantage server, you can use
VNC. It works like PCAnywhere but there is no installation for the client
and the exe fits on a floppy (or a server folder). You use the server name
and a password to log in and you have direct control as if you were at the
server. Then just use your normal procedure. The best part is it is free.
You can download it from ATT UK Research at...
http://www.uk.research.att.com/vnc
I started using it a few months ago and now restart data collection PCs from
my desk. No more running around. I suspect this is not the answer you were
looking for but I hope it helps. Good luck.
Aaron Hoyt
System Administrator
Design Standards Corp.
PO Box 1620
Charlestown, NH 03603
Tel 603-826-7744
<mailto:Aaron@...>
Sent: Thursday, October 12, 2000 4:33 PM
To: vantage@egroups.com
Subject: [Vantage] ending Progress/Vantage user sessions form locations
other than t he Vantage database server
All-
Does anyone know if this is possible using any method with Vantage 4.0 and
Progress 9? I have tried for months to get a solution form Epicor or
Progress and they have basically told me it is not possible, even though we
were able to do this before we went to Vantage 4.0 this summer.
Sent: Tuesday, August 01, 2000 2:49 PM
To: 'tim.goertz@...'
Subject: RE: Can not disconnect user in new release of Progress (9.0)
form anywhere but the consol
Tim,
Received your SupportNet call regarding the following:
We are trying to disconnect Progress users
from WIN95 or Win NT clients on an NT network. We are trying to do this with
the _mprshut.exe command (our icon reads like this:
V:\progress\bin\_mprshut.exe v:\vantage\db\vantage.db -N TCP -H vantage -S
vantage, which Doug Kunze form Progress helped us get set up, just like we
used to be able to with Progress 8.1. The icon will open up the window that
shows us all the
active users but we unable to disconnect anyone we select (with the
exception of yourself). We are signed on as administrator. The function
works fine on the Progress database server itself. This an essential functio
for us to be able to do with the large number of users and multiple sites we
oocasionally have record loks that ened to be ended.
Call opened by: tim.goertz@...
We have used this before as well and you are correct. It will only allow you
to kill yourself and not any other user(s). Only at the Console and with
the correct rights will you be able to kill any other users.
Thanks, Jay Erickson
Vantage Technical Support Analyst
Epicor Software Corp.
jaerickson@...
SupportNet: http://www.epicor.com
Tim Goertz
Aaron Hoyt
PO Box 1620
Tel 603-826-7744
<mailto:Aaron@...>
All-
Tim,
shows us all the
jaerickson@...
Tim Goertz
