Eng. Workbench check in "Description of Change" text box prompt
Yep, that's it! Thanks.
Does anyone know where the entered data into the "Description of Change" dialog is saved to?
I've checked in developer mode, tracing and I've scanned over the schema.
steps taken:
ECO group
Action>check out part
Make MOM change
Action>Revision>Check in
Then a test box appears with OK and Cancel. Its titled "Description of Change". The text area is defaulted with the static value of "ECO Group" followed by my ECO group name and my ECO group description.
IF I change or add dialog into this white space dialog text box and click OK, where is that saved to?
This is the audit log, Jim.
I think one can view the audit log in part tracker. I’m sure there are other places you can view as well.
M. Manasa Reddy
manasa.reddy@...
[d] 281-994-3483
[c] 773-401-4126
Sent: Thursday, May 22, 2014 3:17 PM
Subject: [Vantage] Eng. Workbench check in "Description of Change" text box prompt
steps taken:
ECO group
Make MOM change
Do you know the table name?
I don't see a table in 9.05 called auditlog
and i don't see the test data i used in my check in within any of the aud* tables of:
audithed
auditrev
audirsched
Does anyone know the table name to where this is saved to?
I've tried all of the traditional means to determine this.
thank you.
steps taken:
ECO group
Make MOM change
I believe it is PartAudit
Sent: Friday, May 23, 2014 8:04 AM
Subject: [Vantage] Re: Eng. Workbench check in "Description of Change" text box prompt
thank you.
steps taken:
ECO group
Make MOM change
