Anyone knows where the entry for OrderHed.RepRate is? Thanks a lot?
If you mean in the UI, it’s in Sales Order Entry under Header > Header Salesperson (this is in 10.2.300)
oh, hello @Ernie.
It will default from the workforce setup if you are trying to setup a default rate for the sales person. Otherwise, do what @ernie said.
Thanks Ernie. The field you highlighted is OrderDtl.RepRate. The default value of OrderDtl.RepRate is OrderHed.RepRate.
If you go under Header > Header Salespersons, the fields are OrderHed.RepRate1 through RepRate5. If you go under Lines > Commissions, you get OrderDtl.RepRate1 through RepRate5.
And yes, the Lines > Commissions tab will default from the Header > Header Salesperson tab, which as @bderuvo pointed out, defaults from the salesperson’s Work Force record.
Hi Bryan!
