EpiBinding issue in Customizations
I appreciate the reply Jose. Specifically I'm trying to bind to LaborDtl.LaborNote on the Start Setup Activity form in MES (Epicor.Mfg.UI.App.StartSetupActivityEntry).
Is there any way to add a field to the data set? A work around if it's not generally available on that form?
Nick Skrede
--- In vantage@yahoogroups.com, Jose Gomez <jose@...> wrote:
> Table, Field, and Form would be helpful to know... you can't just type in
> fields which aren't availale in the drop down that usually means this field
> is not available on the data set.
> *Jose C Gomez*
> *Software Engineer*
> *T: 904.469.1524 mobile
> E: jose@...
> http://www.josecgomez.com
> <http://www.linkedin.com/in/josecgomez> <http://www.facebook.com/josegomez>
> <http://www.google.com/profiles/jose.gomez> <http://www.twitter.com/joc85>
> <http://www.josecgomez.com/professional-resume/>
> <http://www.josecgomez.com/feed/>
> <http://www.usdoingstuff.com>
> *Quis custodiet ipsos custodes?*
> On Tue, Mar 26, 2013 at 3:29 PM, nskrede@... <nskrede@...>wrote:
> > I've had a lot of success in setting up UD codes and linking them to
> > EpiCombo boxes for us in my customizations (linking the UD codes to VB
> > fields such as JobOper.Character01); but I'm having an issue binding an
> > EpiCombo box to a table and field that aren't automatically listed in the
> > dropdown. When I manually type the table.field (which I know exists) in the
> > EpiBinding location of the customization tools it gives me the following
> > error:
> > Error Detail
> > Object reference not set to an instance of an object.
> > Stack Trace
> > at
> > Epicor.Mfg.UI.Customization.CustomPropertySetManager.AutoAddEpiComboProperties(EpiTransaction
> > oTrans, EpiComboDesigner ecboDesigner, GridItem changedItem)
> > Any advice/direction would be appreciated.
> > Thanks.
I've had a lot of success in setting up UD codes and linking them to EpiCombo boxes for us in my customizations (linking the UD codes to VB fields such as JobOper.Character01); but I'm having an issue binding an EpiCombo box to a table and field that aren't automatically listed in the dropdown. When I manually type the table.field (which I know exists) in the EpiBinding location of the customization tools it gives me the following error:
Error Detail
Stack Trace
at Epicor.Mfg.UI.Customization.CustomPropertySetManager.AutoAddEpiComboProperties(EpiTransaction oTrans, EpiComboDesigner ecboDesigner, GridItem changedItem)
Thanks.
*Jose C Gomez*
*Software Engineer*
E: jose@...
> error:
> Error Detail
> Stack Trace
> at
> Thanks.
