Just wanted to share some info I discovered that I couldnt find a reference to here on EpiUsers in hopes it will help someone in the future.
If you are using an EpiCombo to pull in UserCodes, there are several ways that you limit the selection to your specific code type (ie. CodeTypeID = ‘AppClass’):
EpiFilters
SearchFilter
At first glance they both provide the same results, however, if you do NOT use SearchFilter, the OpenWith functionality will not work.
