In the file section get this download. it is the one I started with BAM_Alert_OrderRel_DropShip.zip<http://f1.grp.yahoofs.com/v1/PPg9UfsYhhoG6K_oyDLE4fg-NCPQt6xF2xelGUOMe4x-oLPqJZ69PLurjEsphEDYM--FW-g-tbwhTJAz-urCI3JZ50IKw94LiWOf5HmpEbd6qutO/BAM_Alert_OrderRel_DropShip.zip>. The word doc explains how to setup a bam and where to put on the server.
I have a couple of samples in the BAM folder of the file section. What is the table or alert you are wanting to make, I may have one that I can make a sample out of.
The basics are set the table name at the top and then you can print any data from that table or use it to read other data. There is also an OLDTablename of data available if you want to show a change from this to that.
If you have conditional alerts and don't want to send then set the Sendmail = False and it won't generate the alert.
Greg Payne
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Turgeon, Bill
Sent: Monday, March 11, 2013 11:29 AM
Subject: RE: [Vantage] RE: Epicor 9.05.700C - Global Alerts
I'm pretty much an Epicor rookie.
Can you please expand on this with some details or a sample?
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf
Of Greg Payne
Sent: Monday, March 11, 2013 11:23 AM
Subject: [Vantage] RE: Epicor 9.05.700C - Global Alerts
No. I just setup BAMs and use .p programs to make a meaningful message.
Greg Payne
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>
[mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com> ] On
Sent: Monday, March 11, 2013 9:28 AM
To: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>
Subject: [Vantage] Epicor 9.05.700C - Global Alerts
Is there any way to modify the subject and/or message of a global alert?
They currently show the alert number and are pretty much useless as
deployed.
Regards,
Bill Turgeon
Director, Information Technology
Coto Technology, Inc.
66 Whitecap Drive
North Kingstown, RI 02852
Ph: 401-583-7223
Cell: 401-368-9938
Fax: 401-942-0920
E-mail: bturgeon@...<mailto:bturgeon%40cotorelay.com> <mailto:bturgeon%40cotorelay.com>
<mailto:bturgeon%40cotorelay.com> <mailto:jbentley@...<mailto:jbentley%40cotorelay.com>
<mailto:jbentley%40cotorelay.com> <mailto:jbentley%40cotorelay.com>>
P Please consider the environment before printing this email.
This e-mail and any attachments are for the sole use of the intended
recipients and may be privileged or confidential. Any distribution,
printing or other use by anyone else is prohibited. If you are not an
intended recipient, please contact the sender immediately, and
permanently delete this e-mail and attachments.
CONFIDENTIALITY NOTICE
The information contained in this communication, including attachments,
is privileged and confidential. It is intended only for the exclusive
use of the addressee. If the reader of this message is not the intended
recipient, or the employee or agent responsible for delivering it to the
intended recipient, you are hereby notified that any dissemination,
distribution or copying of this communication is strictly prohibited. If
you have received this communication in error, please notify us at
727-578-6280 and immediately delete the communication.
"This (document/presentation) may contain technical data as defined in
the International Traffic In Arms Regulations (ITAR) 22 CFR 120.10.
Export of this material is restricted by the Arms Export Control Act (22
U.S.C. 2751 et seq.) and may not be exported to foreign persons without
prior approval form the U.S. Department of State."
The information contained in this communication, including attachments, is privileged and confidential. It is intended only for the exclusive use of the addressee. If the reader of this message is not the intended recipient, or the employee or agent responsible for delivering it to the intended recipient, you are hereby notified that any dissemination, distribution or copying of this communication is strictly prohibited. If you have received this communication in error, please notify us at 727-578-6280 and immediately delete the communication.
Greg Payne
Of Greg Payne
Greg Payne
deployed.
Regards,
Bill Turgeon
66 Whitecap Drive
Ph: 401-583-7223
Cell: 401-368-9938
Fax: 401-942-0920
