Sharing the results. POHeader.POTYPE field can be blank. This is a bug in 9.05.702 (I fixed it by making the field mandatory in Extended Properties.)
If a Blank PO TYPE is processed you only see a problem when doing a receipt and want the price to pull thru.
Patrick Winter
Sent: Wednesday, August 10, 2016 08:05
Subject: [Vantage] Epicor 9.05.702 - PO Receipt won't pull thru Supplier Price
PO for a Stock item, the part has a PRICE LIST entry for the base price, when my purchasing person does a receipt the Lead Time days pulls thru but the Supplier Price is blank.
Not sure what to look at all the UOM fields are the same EA.
Anyone have any suggestions?
Patrick Winter
This e-mail and any attachments may contain confidential and privileged information. If you are not the intended and/or named recipient or recipients, please notify the sender immediately by return e-mail, delete this e-mail and destroy
any copies. Any dissemination or use of this information by a person other than the intended recipient or recipients is unauthorized and may be illegal. Any views or opinions expressed in this email are those of the author and do not necessarily represent
those of the Specialty Screw Corporation. Warning: Although precautions have been taken to make sure no viruses are present in this email, Specialty Screw Corporation cannot accept responsibility for any loss or damage that may arise from the use of this email
or attachments.
This e-mail and any attachments may contain confidential and privileged information. If you are not the intended and/or named recipient or recipients, please notify the sender immediately by return e-mail, delete this e-mail and destroy any copies. Any dissemination
or use of this information by a person other than the intended recipient or recipients is unauthorized and may be illegal. Any views or opinions expressed in this email are those of the author and do not necessarily represent those of the Specialty Screw Corporation.
Warning: Although precautions have been taken to make sure no viruses are present in this email, Specialty Screw Corporation cannot accept responsibility for any loss or damage that may arise from the use of this email or attachments.
