Okay, thanks a lot for your input. It hasn't gone to waste.
Sent: Thursday, August 18, 2011 4:50 PM
Subject: Re: [Vantage] Epicor 9 Adapters
Yeah
Yeah
On Thu, Aug 18, 2011 at 4:16 PM, Ted Koch <tkoch77@...> wrote:
> By run a trace, you mean enabling trace logging and looking over the
> output?
> From: Waffqle <waffqle@...>
> Sent: Thursday, August 18, 2011 3:55 PM
> Yeah. There is another document floating around that documents the BOs, but
> I honestly haven't looked at it much. By the time it was available, I'd
> already learned most of the hard way. It's generally easier/preferable to
> run a trace as opposed to building your own process.
> On Thu, Aug 18, 2011 at 3:53 PM, Ted Koch <tkoch77@...> wrote:
> > I've only been working with Epicor for about 2months, you're referring to
> > the ICE Tools handbook?
> > Sent: Thursday, August 18, 2011 3:50 PM
> > There are bits of info here and there across various documents. I don't
> > know
> > of any comprehensive source outside of this list. There is a
> customization
> > handbook. If you're already writing straight to the adapters, I'd wager
> > you've eclipsed the vast majority of what's in that book.
> > If you want it, I think it's available on EpicWeb; that failing, your CAM
> > should be able to hook you up.
> > On Thu, Aug 18, 2011 at 3:45 PM, Ted Koch <tkoch77@...> wrote:
> > > Yes me too. I am very new to Epicor, still learning how some of the
> > coding
> > > works. Is there an Epicor dev book or anything like that with
> references
> > for
> > > some of this stuff?
> > > Sent: Thursday, August 18, 2011 2:08 PM
> > > Ah! I missed that! Glad you got it figured out.
> > > On Thu, Aug 18, 2011 at 2:02 PM, Ted Koch <tkoch77@...> wrote:
> > > > I figured out what my problem was, apparently the P in Project in
> > > > ("oTrans_ProjectAdapter") needed to be lowercase. Once I did this it
> > > worked
> > > > fine. Before I did this oTrans_ProjectAdapter was returning nothing,
> > now
> > > it
> > > > returns the ProjectAdapter.
> > > > Dim oTrans_ProjectAdapter As ProjectAdapter =
> > > > DirectCast(csm.TransAdaptersHT("oTrans_projectAdapter"),
> > ProjectAdapter)
> > > > Sent: Thursday, August 18, 2011 10:02 AM
> > > > If I'm following correctly, you're running this code on the project
> > > screen.
> > > > If so, the problem is coming because you're creating a new adapter.
> > > What's
> > > > happening is that you ARE creating the new project, but because your
> > > > adapter
> > > > is not associated with the UI, nothing is updating.
> > > > For this to work properly you need to use an adapter that is
> connected
> > to
> > > > the dataviews and such. While it's technically possible to do this
> with
> > a
> > > > new adapter; it is far and away easier to just use the existing
> Epicor
> > > > adapter. You can fetch it with the following code:
> > > > QuoteAdapter oTrans_adapter = (QuoteAdapter)csm.TransAdaptersHT[
> > > > "oTrans_adapter"];
> > > > Obviously, that's for a quote but it should be pretty straight
> forward
> > to
> > > > switch it over to a project or what have you.
> > > > On Thu, Aug 18, 2011 at 9:31 AM, Ted Koch <tkoch77@...> wrote:
> > > > > I am passing a value from the quote form to the project form with
> > > > > launchformoptions.contextvalue. I would like when the page has
> loaded
> > > for
> > > > it
> > > > > to create a new project (what would happen if you clicked new on
> the
> > > > > standard toolbar) and then place that variable into the project ID
> > > > textbox.
> > > > > I'm okay up until the point of creating a new project using some
> > code,
> > > I
> > > > > used what was in the Object Explorer, but I'm guessing that has to
> be
> > > > > modified so it will create a new project?
> > > > > Sent: Thursday, August 18, 2011 9:24 AM
> > > > > Sure, we use them all the time?
> > > > > What are you expecting/wanting that code to do? Also, where are you
> > > > running
> > > > > it from?
> > > > > On Thu, Aug 18, 2011 at 8:25 AM, tkoch77 <tkoch77@...>
> wrote:
> > > > > > Does anyone have experience with coding Epicor adapters? I can't
> > seem
> > > > to
> > > > > > get them to work. I want to create a new Project with code. So
> far
> > > this
> > > > > is
> > > > > > what I have, it doesn't give any errors, but it doesn't do
> > anything.
> > > > > > Dim oTrans_ProjectAdapter As ProjectAdapter = New
> > > > > > ProjectAdapter(ProjectEntryForm)
> > > > > > oTrans_ProjectAdapter.BOConnect()
> > > > > > Dim NewProject As Boolean = oTrans_ProjectAdapter.GetNewProject()
> > > > > > oTrans_ProjectAdapter.Dispose()
> > > > > > If anyone could help me understand this I would be very thankful.
> > > > > > -Ted
> > > > > *Waffqle Driggers*
> > > > > *High End Dev, System Design, Profit Drinking
> > > > > *:: 904.962.2887*
> > > > > *:: waffqle@...*
> > > > > *:: NO FAXES*
> > > > > [Non-text portions of this message have been removed]
> > > > > Useful links for the Yahoo!Groups Vantage Board are: ( Note:Â You
> > must
> > > > have
> > > > > already linked your email address to a yahoo id to enable access. )
> > > > > (1) To access the Files Section of our Yahoo!Group for Report
> Builder
> > > and
> > > > > Crystal Reports and other 'goodies', please goto:
> > > > > http://groups.yahoo.com/group/vantage/files/.
> > > > > (2) To search through old msg's goto:
> > > > > http://groups.yahoo.com/group/vantage/messages
> > > > > (3) To view links to Vendors that provide Vantage services goto:
> > > > > http://groups.yahoo.com/group/vantage/linksYahoo! Groups Links
> > > > *Waffqle Driggers*
> > > > *:: 904.962.2887*
> > > > *:: waffqle@...*
> > > > *:: NO FAXES*
> must
> > > have
> > > > (1) To access the Files Section of our Yahoo!Group for Report Builder
> > and
> > > *Waffqle Driggers*
> > > *:: 904.962.2887*
> > > *:: waffqle@...*
> > > *:: NO FAXES*
> > > Useful links for the Yahoo!Groups Vantage Board are: ( Note:Â You must
> > have
> and
> > *Waffqle Driggers*
> > *:: 904.962.2887*
> > *:: waffqle@...*
> > *:: NO FAXES*
> have
> > (1) To access the Files Section of our Yahoo!Group for Report Builder and
> *Waffqle Driggers*
> *:: 904.962.2887*
> *:: waffqle@...*
> *:: NO FAXES*
> Useful links for the Yahoo!Groups Vantage Board are: ( Note:Â You must have
>Â
*Waffqle Driggers*
*:: 904.962.2887*
*:: waffqle@...*
*:: NO FAXES*
Useful links for the Yahoo!Groups Vantage Board are: ( Note:Â You must have already linked your email address to a yahoo id to enable access. )
(1) To access the Files Section of our Yahoo!Group for Report Builder and Crystal Reports and other 'goodies', please goto: http://groups.yahoo.com/group/vantage/files/.%c2%a0
