Mark,
I have found and worked with everything you have discussed with ease. I really do like the new interface coming from 8.x so I am in agreement with you regarding all the help and new wizards available to us.
Thanks for the inside info. Though I was already familier with what you are describing here, the info is useful to note for others out there.
Chris,
Chris,
--- In vantage@yahoogroups.com, "Mark Wonsil" <mark_wonsil@...> wrote:
> Hi Chris,
> > I have to hand it to Epicor as I am entertaining the fact
> > that in Epicor 9 they have now allowed us the opportunity to
> > use C# within our UI Form Customizations and I am now moving
> > forward with C# versus VB.NET and things are working out
> > quite well. The problem I have is that I have yet to find any
> > object explorer tools or references for C# only VB.NET. I
> > guess I don't expect to find much since a lot of us have come
> > from the VB.NET customizations with 8.x but if anyone else
> > using C# has or knows of Epicor releasing an Object Explorer
> > tailored towards C# please let me know. We are getting by
> > quite nicely but sometimes its just nice to have a reference.
> Not only are they enteraining C#, they encourage it if you want to use the
> web-based forms. Epicor 9 has a C# -> Javascript converter but not a VB.Net
> -> Javascript converter. So if you're using the web interface and you want
> your customizations to work on the web, you must use C#.
> Because of this, you will find under Customization Maintenance, a VB.Net ->
> C# Converson Helper. In 9.04.504B, you will find a "Selected Issue
> Helper..." button at the bottom of the Compile/Script Errors tab. Click on
> the Custom Code tab to see the VB.Net -> C# helper.
> When in customization mode, there is an Object Explorer but it only gives VB
> examples.
> Also in Customization Mode, you will find under the Tools menu some wizards
> to generate code: Modify Extended Properties, Simple Search, Add UD table as
> a Child, and a couple of other tasks that you would normally look up in the
> Cusomtization Guide. Pretty cool.
> Mark W.
