Epicor 9 Data Dictionary
Go ahead and zip up the results and post it alongside the V8 version
as E9DataDictionary.zip.
-bws
Of mattcald_73
Sent: Monday, June 28, 2010 5:39 PM
Subject: [Vantage] Re: Epicor 9 Data Dictionary
This worked great! I did have to change the -Mm parameter to 1024, but
that was it. Easy! Thanks!
--- In vantage@yahoogroups.com, "bw2868bond" <bwalker@...> wrote:
> Create a shortcut with these properties:
> E:\Epicor904\oe101c\bin\prowin32.exe \\<server
name>\Epicor904\db\mfgsys -Mm 4096 -N TCP -H <server name> -S 9000 -p
<path to htmldict.w> -U sysprogress -P sysprogress
> I happen to have Epicor9 on E: in this example - replace <server name>
with your vantage db server's name and <path to....> with where you put
the html dictionary program files
> --- In vantage@yahoogroups.com, "Brian W. Spolarich " <bspolarich@>
wrote:
> > Well, the DataDictionary HTML files are created by the execution
of
> > the included .w and .p files. However I am not sure how to execute
them
> > so that they'll work with the proper Progress database selected.
You
> > can run prowin32.exe and open/execute the .w file in the Procedure
> > Editor, and execute it from there, but its not clear from there how
one
> > actually selects the proper database so that the program will do its
> > thing.
> > Perhaps someone with some understanding of the Progress
environment
> > has some insight?
http://tech.groups.yahoo.com/group/vantage/files/DataDictionary.zip
> > -brian
Behalf
> > Of mattcald_73
> > Sent: Monday, June 28, 2010 2:47 PM
> > Subject: [Vantage] Epicor 9 Data Dictionary
> > Brian S shared a Vantage 8.03 HTML Data Dictionary a while back. It
is
> > an AWESOME tool, too! Does anyone have one for Epicor 9? We are
going
> > live with E9 later this year, and I was wondering if I am going to
be
> > stuck with the delivered Data Dictionary.
> > --Matt
> > Useful links for the Yahoo!Groups Vantage Board are: ( Note: You
must
> > have already linked your email address to a yahoo id to enable
access. )
> > (1) To access the Files Section of our Yahoo!Group for Report
Builder
> > and Crystal Reports and other 'goodies', please goto:
> > http://groups.yahoo.com/group/vantage/files/.
> > http://groups.yahoo.com/group/vantage/messages
> > (3) To view links to Vendors that provide Vantage services goto:
> > http://groups.yahoo.com/group/vantage/linksYahoo! Groups Links
Brian S shared a Vantage 8.03 HTML Data Dictionary a while back. It is an AWESOME tool, too! Does anyone have one for Epicor 9? We are going live with E9 later this year, and I was wondering if I am going to be stuck with the delivered Data Dictionary.
--Matt
Well, the DataDictionary HTML files are created by the execution of
the included .w and .p files. However I am not sure how to execute them
so that they'll work with the proper Progress database selected. You
Editor, and execute it from there, but its not clear from there how one
thing.
Perhaps someone with some understanding of the Progress environment
has some insight?
-brian
Of mattcald_73
--Matt
E:\Epicor904\oe101c\bin\prowin32.exe \\<server name>\Epicor904\db\mfgsys -Mm 4096 -N TCP -H <server name> -S 9000 -p <path to htmldict.w> -U sysprogress -P sysprogress
I happen to have Epicor9 on E: in this example - replace <server name> with your vantage db server's name and <path to....> with where you put the html dictionary program files
--- In vantage@yahoogroups.com, "Brian W. Spolarich " <bspolarich@...> wrote:
> thing.
> has some insight?
> -brian
> Of mattcald_73
> --Matt
Good Day Matt:
Try System Management >> Data Dictionary Viewer. It indicates
Required fields.
Or in any field, Help ( on tool bar) >> Field help >> Technical
len.hartka@...
len.hartka@...
Of mattcald_73
--Matt
This e-mail and any attachments may contain proprietary and/or confidential information. If you are not the intended recipient, please notify the sender immediately by reply e-mail or at 410-472-2900 and then delete the message without using, disseminating, or copying this message or any portion thereof. With e-mail communications you are urged to protect against viruses.
This worked great! I did have to change the –Mm parameter to 1024, but that was it. Easy! Thanks!
> > thing.
> > has some insight?
> > -brian
> > Of mattcald_73
> > --Matt
